power loss once engine gets hot?
/ power loss once engine gets hot? #21
Another great thread.
l'm still learning new stuff daily but l'll try to answer this one.
No fuel no power and it's not going to run, Low fuel pressure low power. Rule of thumb on a Diesel. It's a over heating water Temp. problem. So how fuel is getting it hot is the big question on this thread?
Lean air/fuel mixtures cause engines to run hotter than richer a/f ratios.
Power loss and overheating--while separate symptoms--could point to a common cause.
My question: Are you sure there's not some sort of "smart engine monitoring system" that protects against overheating, over-revving or low engine-oil pressure situations? Would that reduce/limit horsepower?
/ power loss once engine gets hot? #22
Valve adjustment time. Should've been done by now anyway with 600hrs so at least pull the valve cover and check the gaps.
/ power loss once engine gets hot? #23
Familiar with this model.
The fuel governor on a John Deere 5103 tractor is a crucial component that helps regulate the engine’s fuel supply to maintain a consistent speed, especially under varying loads. If you’re experiencing issues with the fuel governor, it might be related to the injection pump, as the governor is integrated within it1.
/ power loss once engine gets hot? #24
Lean and rich fuel mixtures aren’t really relevant when it comes to diesels. They vary the amount of fuel injected to make more power. When at idle very lean and when making full power more fuel injected. Unlike a gas engine, a diesel can be over fueled and still run fine but make quite a bit of black smoke. Over fuel them to much you can start burning a piston which usually happens when an injector sticks open.
/ power loss once engine gets hot? #25
Switch from white to pork fried. Significantly more btu/cu cm.
/ power loss once engine gets hot? #27
Last Fall, there was a thread where Rancher Ed wrote a good short explanation of how engine heat is different in gas vs diesel engines. He covers running rich vs lean effects in both types of engine. Here's the link. His message is #73.
It's worth reading.
rScotty
/ power loss once engine gets hot? #28
You can have a full radiator but that don't mean the ratio is correct
willy
So i re-fueled up the tractor and haven't had the issue since when i had the issue it was running low on diesel. The tractor also sites outside so it's exposed to rain.
As far as the over heating issue i think it's because the bush hog is to large for the tractor.
/ power loss once engine gets hot? #30
When the tank is run low it is much more likely to draw water or contaminants into the fuel lines, causing a multitude of problems.
I think I would be investigating the fuel quality in the tank and sediment bowl, if it has one.
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
2023 Bobcat L28 (A64126)
2023 Bobcat L28...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Engine (A59228)
Engine (A59228)
2016 FORD E450 SHUTTLE BUS (A59914)
2016 FORD E450...
