Power line safety procedures
/ Power line safety procedures #11
We had a tree fall on our power lines feeding our yard, it was blocking the driveway and the tree was just leaning against the line. We called the power company and they said "there is storm damage in the south and we can't get a truck to you for 2 weeks at least." Well it's a good think the loader tractor has 6 rubber tires cause we couldn't stay blocked in at the yard for two weeks. Just picked it up with the loader and pushed it off.
/ Power line safety procedures #12
Even if you know a power line is de-energized and down, don't assume it will stay that way even if the power company has not repaired a downed line. Many people have generators now and some may not know how to disconnect their wiring from the power system. Feeding 240v through a transformer produces primary voltage through that transform and back through the system. So, if a primary line is cut and down, don't assume the "load" side is de-energized even though the source side is.
/ Power line safety procedures #13
Was the powerline energized? If so, you got away lucky, or their was a good path through the tree to ground. There are MANY incidents with cranes and trucks contacting overhead lines and blowing out all the tires.
/ Power line safety procedures #14
I need you to buy me a lottery ticket,you got lucky.
A very good point.
/ Power line safety procedures #16
The power company that services our area says "if a line is not grounded, it is not dead" - so, they attach a grounding line to each wire before they do any work even when they were the ones who pulled the switch. They even ground the common/ground wire. They also will no longer allow a technician to work on a "feed/hot line" if he is by himself. He can work on the ground/common/return line when alone - but there must be at least two techs for then to be able to service a "hot" wire - which usually means they bring two trucks since they seldom have two techs in one truck.
This has been a real benefit as they frequently find "dead" wires to be energized by a private generator while they are repairing downed/broken lines after/during a storm.
/ Power line safety procedures #17
Good video--thanks for posting.
Though I think it could have benefited from some editorial input, saying:
STAY OFF THE ******* WHILE DRIVING, unless you have a proven ability to do two things at once...and I realize even that is very subjective and NOT as good as my first observation.
These comments, below, from the youtube video, made some sense to me:
"USNVA1 month ago
Step potential conducting through each leg is possibility, but to minimize the shock, running is every bit as effective as keeping feet together. When a person runs they only have one point of contact touching the ground in the line of step potential. Walking has two points touching at once.
Alex Mamer
Alex Mamer1 month ago
You're right, that way your body would not complete a circuit."
However, upon further reflection it occurred to me that perhaps "shuffling" is advisable over running, in case you ARE injured/shook up, don't know it, and fall down on the (potentially) energized ground (no pun intended)--or even trip on debris, as you're in unfamiliar territory, it could be dark, slippery, etc.... Just my .02.
But I'll be passing the OP's video on to others so, again, thank for posting.
My Hoe
Yes, I thought it would be a good reminder for those of us that have had some safety training, and maybe an eye opener for those of us that have not.
About 20 years ago a friend of mine was driving in his pickup truck and encountered black ice and a dump truck. He managed to not collide with the dump truck, but in taking evasive maneuvers he hit a power pole. The dang power transformer (pole pig) fell on the cab of his pickup and dang near smashed him. he managed to jump out of the truck without getting shocked, but then rolled down a steep hill. That didn't do him any good. And it took some time for him to crawl back up this steep icy hill. He crested the hill about the time Law Enforcement arrived. I wondered what had happened to him. You just never know the things that might befall you. He was in his 20's, it was not like he was some old decrepit dude. Like me.:)
/ Power line safety procedures #19
I think grounding de-energized lines before working is standard practice for all utilities. If there it is a fully grounded neutral it is usually acceptable to connect the three phase wires to the neutral because it is connected to many grounds along the circuit.
Another hazard is induction from parallel lines. In 1967 I saw an unintended demonstration. Our crew had de-energized a stretch of 3 phase 12 kv distribution line strung below a 72 kv transmission line. Two of our crew were up a 90 degree corner pole and had grounded the three phases by attaching the ground clamp to one of the guy wires which were in turn bonded to the system neutral. One of the linemen decided the ground chain was in his way. I even remember him saying so, and stating he would move it to the other guy-wire, 90 degrees from the one it presently was on. He disconnected the clamp from the existing guy wire (the other three clamps were still on the phases of the de-energized phases), and while holding that clamp in one hand, grabbed the guy wire to which he was going to transfer the ground clamp with the other hand. That's when he let out a heck of a noise, yelling "I can't let go". It went on for a few seconds. Luckily, the second person was an experienced and quick-thinking journeyman; plus I think he already had pliers in his hand for doing some work. He immediately reached over and cut the ground chain. No real harm was actually done and they both continued working, after we sent up a new ground chain.
The person who made the mistake was a fourth-year lineman who had been in to write his journeyman's exam that same week. Once it was clear things were OK, our foreman yelled up something like "that's a heck of a thing to do for someone who just wrote his journeyman's exam", but not in those words.
The lineman broke a couple of rules: the ground end should always be connected before the phases and rubber gloves and hot stick are to be used when installing the phase grounds.
This incident is also a good reminder that low voltage systems can be just as deadly as high voltage systems.
/ Power line safety procedures #20
This idiot needs to watch a video about not using a cell phone while you drive. He could have killed someone instead of hitting the pole.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
KUBOTA L3301 TRACTOR (A62130)
KUBOTA L3301...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
SDLanch SDLGC80 (A60463)
SDLanch SDLGC80...
