k0ua
Epic Contributor
This video might help a bit if out brush hogging you hit a guy wire and knock a power line down on your tractor.
The guy the hooked up the electric service to my house said he accidentally cut a 7,200 volt line with a chain trencher. He said it welded the chain to the bar.
We had a tree fall on our power lines feeding our yard, it was blocking the driveway and the tree was just leaning against the line. We called the power company and they said "there is storm damage in the south and we can't get a truck to you for 2 weeks at least." Well it's a good think the loader tractor has 6 rubber tires cause we couldn't stay blocked in at the yard for two weeks. Just picked it up with the loader and pushed it off.
I need you to buy me a lottery ticket,you got lucky.We had a tree fall on our power lines feeding our yard, it was blocking the driveway and the tree was just leaning against the line. We called the power company and they said "there is storm damage in the south and we can't get a truck to you for 2 weeks at least." Well it's a good think the loader tractor has 6 rubber tires cause we couldn't stay blocked in at the yard for two weeks. Just picked it up with the loader and pushed it off.
Even if you know a power line is de-energized and down, don't assume it will stay that way even if the power company has not repaired a downed line. Many people have generators now and some may not know how to disconnect their wiring from the power system. Feeding 240v through a transformer produces primary voltage through that transform and back through the system. So, if a primary line is cut and down, don't assume the "load" side is de-energized even though the source side is.
"USNVA1 month ago
Step potential conducting through each leg is possibility, but to minimize the shock, running is every bit as effective as keeping feet together. When a person runs they only have one point of contact touching the ground in the line of step potential. Walking has two points touching at once.
Alex Mamer
Alex Mamer1 month ago
You're right, that way your body would not complete a circuit."
The power company that services our area says "if a line is not grounded, it is not dead" - so, they attach a grounding line to each wire before they do any work even when they were the ones who pulled the switch. They even ground the common/ground wire. They also will no longer allow a technician to work on a "feed/hot line" if he is by himself. He can work on the ground/common/return line when alone - but there must be at least two techs for then to be able to service a "hot" wire - which usually means they bring two trucks since they seldom have two techs in one truck.
This has been a real benefit as they frequently find "dead" wires to be energized by a private generator while they are repairing downed/broken lines after/during a storm.
