Gregster613
- Joined
- Apr 19, 2009
- Messages
- 1,031
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hello Hydraulic wizards, I have been having on-going problems with my TYM Nimco loader valve and I found a Nimco distributor with a matching number valve to fit. It looks almost exactly the same as my old valve - which is not available through TYM - says Jordon's tractor.
The end caps with the float for loader and regen for curl/dump look different but have the same functions. I added the schematic as an attachment to this message. I plan to order the valve but when I asked him to add the power beyond sleeve to the order, he asked me to send him all the info about the PB sleeve and he'd see if they had it?
What info would he be needing to have? I've never seen a PB sleeve, the one in my current valve was installed by my dealer's mechanic; I'm hoping it will interchange with the new valve but to be sure I had what I needed on-hand when I do the replacement I asked him to send me a PB sleeve along with the new valve, and I get questions from the distributor about the PB sleeve??
I could sure use a touch of guidance here as I'd really like to get all the proper pieces at one time/shipment. Or is a PB sleeve something you get separate from the valve itself?? Do I need to search out a hydraulic shop to source one? I thought that a Nimco valve distributor would know all about this stuff but perhaps I'm wrong? I do know that I'm not the most knowledgeable per hydraulics but I can change out a valve and if need be get longer or shorter hoses, or different style adapters if needed. I don't know much about the PB sleeve except what it does and is called. Maybe that's what I did wrong - called it a sleeve?? - is it called something else?
Please view the attached PDF and correct me if I have my terminology wrong and point me in the direction I need go to get a power beyond fitting that fits this new valve. The PB feeds my 3 scv's then continues on to the 3ph and tank. Thanks for guidance. Greg
View attachment New Loader valve.pdf
