Power Beyond question
/ Power Beyond question #1
MR_NC
NW Ohio
2720 TLB
When sizing a valve to be used on the power beyond (add on, not factory).
Should the valve be sized to the total tractor or implement flow?
Thanks in advance!
Best regards,
Sean
/ Power Beyond question #2
implement flow.
/ Power Beyond question #3
Just to be clear, the valve needs to be rated for the entire flow that the implement pump puts out. If your tractor has a 5 GPM for the power steering pump and a 10 GPM pump for all implement use, then the valve needs to be able to flow 10 GPM. If you use a motor spool that takes 8 GPM, you still need a valve that takes the 10 GPM that the implement pump puts out.
You NEVER want to restrict the main flow for any extended length of time. ;)
Thanks for the quick feedback guys!
If I understand correctly (2720 for instance) the implement side is 5GPM, total GPM of tractor is 10.
Valve would be sized to 5GPM in this case correct?
Thanks again!
Sean
/ Power Beyond question #5
Thanks again!
Sean
Correct. Or even a little larger is perfectly OK-just never smaller.
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
213065 (A64276)
213065 (A64276)
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
