Power Beyond question
/ Power Beyond question #1
MR_NC
NW Ohio
2720 TLB
When sizing a valve to be used on the power beyond (add on, not factory).
Should the valve be sized to the total tractor or implement flow?
Thanks in advance!
Best regards,
Sean
/ Power Beyond question #2
implement flow.
/ Power Beyond question #3
Just to be clear, the valve needs to be rated for the entire flow that the implement pump puts out. If your tractor has a 5 GPM for the power steering pump and a 10 GPM pump for all implement use, then the valve needs to be able to flow 10 GPM. If you use a motor spool that takes 8 GPM, you still need a valve that takes the 10 GPM that the implement pump puts out.
You NEVER want to restrict the main flow for any extended length of time. ;)
Thanks for the quick feedback guys!
If I understand correctly (2720 for instance) the implement side is 5GPM, total GPM of tractor is 10.
Valve would be sized to 5GPM in this case correct?
Thanks again!
Sean
/ Power Beyond question #5
Thanks again!
Sean
Correct. Or even a little larger is perfectly OK-just never smaller.
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
Thorp Stainless Steel Feeder (A65640)
Thorp Stainless...
72in Blue Diamond Grapple Bucket (A65579)
72in Blue Diamond...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2023 John Deere 6145M (A64126)
2023 John Deere...
Rotomec Auger (A64127)
