Pouring fuel from cans
/ Pouring fuel from cans #21
I had some used metal valve stems that I put in mine. Works so much better now.
That'd work great. Pull the actual valve and bob's yer uncle.
And then for real speed hook the valve up to an air compressor!! :)
I put the can in the loader bucket, raise it up and use one of those to get the fuel running.
Yea, I've been doing that for years. Especially with my 14 gallon container.
I took my brand new yellow fuel cans to the fuel station and failed to take the damn "guaranteed not to work" flashback protector or cheesy filter ( whatever it is) out. I was wearing a gallon of the stuff in less than a twentieth of a second.
/ Pouring fuel from cans #24
For gas I have valve stems. For diesel (which I don't do very often) I use round plastic racing gas cans. The hole in the top is about the size of a tennis ball. The caps have the ability to have a flexible tube added to them (I think 3/4") but I just use them with a huge funnel. It takes less than a minute to put 5 gallons of fuel in. Most of the ones I see now are made by VP racing and are square.
/ Pouring fuel from cans #25
/ Pouring fuel from cans #26
For my gas and diesel cans I drill out the air vent with a 3/8" drill bit, then go to the hardware store and buy corks, that press fit into the hole. I do the same with missing snap on caps the filler spout when eventually fall off. Has forked for years.
/ Pouring fuel from cans #27
/ Pouring fuel from cans #28
I get the reasoning behind trying to control the vapors, especially with gas, but always thought the new designs actually released more vapors by causing spills from poorly designed nozzle tips/valves.
I found these at tractor supply for diesel, and the oem sells them for gasoline as well (I now have both, about one year old).
There is a manual vent opposite the spout, it works like a dream! The spout is actually well done as well using
a large and sturdy 'trigger' to rest on the lip of the receiving container.
Anyway, not affiliated in anyway, just stoked to find a can that actually works well.
/ Pouring fuel from cans #29
Or...... you can get one of these:
Works great, will pump a 5gal can in under 2 minutes. I made a little wheeled cart to move around. Only lift the can out of the truck.....
Here is the cart:View attachment 750469
Poor Man's version.
/ Pouring fuel from cans #32
There is a manual vent opposite the spout, it works like a dream! The spout is actually well done as well usingView attachment 750777View attachment 750778 a large and sturdy 'trigger' to rest on the lip of the receiving container.
I looked at those but I just couldn't do it. Almost $50 for a 5 gal. can was too much.
/ Pouring fuel from cans #33
Iuse the cheapest can i can find , install a flex tip and then install a vent. Throw out internal screen and foolish 5 arm required pour spout.
/ Pouring fuel from cans #35
I got the same pump at Harbor Freight and use it to pump off road diesel out of a 55 gal drum. This eliminates a lot of trips to refill 5 gal fuel cans every season. I use barrel lifting chains to move the 55 gal drum using a tractor FEL.
I use a 30 amp hour wheel chair battery for power which I swap back and forth to power my fence row spray pump.
/ Pouring fuel from cans #36
/ Pouring fuel from cans #37
We switched to steel class II? cans years ago which have a 7/8th flexible spout. Yes they cost more but are leak proof, drain fast and last for years. We used to get these for $80.....
You still have to lift it and hold it there. I don't lift cans any more except to get them in the back of the truck after I fill them--I went electric. I don't care what kind of spout it has now. With my auto shutoff pump, I can even fill a lawnmower tank without spillage.
/ Pouring fuel from cans #38
I'm not certain of the OPer, but much of the fuel we use is in the field and no power is aviable.
/ Pouring fuel from cans #39
I use two battery powered pumps. They use AAA batteries. If you can tot a can, you can carry a pump. ;)
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
2016 Hyundai Veloster Hatchback (A59231)
2016 Hyundai...
ALLISON TRANSMISSION (A55745)
ALLISON...
2007 TUG GPU 400/60 28V 60kVA Towable Diesel Generator (A59228)
2007 TUG GPU...
