Pouring fuel from cans
/ Pouring fuel from cans #2
I had some used metal valve stems that I put in mine. Works so much better now.
/ Pouring fuel from cans #3
Those DEFINITELY WORK!. I couldn't believe how fast they allowed to pour.... almost too fast!
/ Pouring fuel from cans #6
Great idea, thanks for sharing. I like the shorter pour time and the batteries won't ever go dead!!
/ Pouring fuel from cans #7
A siphon / shaker hose. Set the can on the fender, shake the hose a couple times, then go check the fluids, etc.. for a couple minutes while the can empties itself.
/ Pouring fuel from cans #8
I should make a video,, (Somebody probably has??)
ANYWAYS,,,
instead of pouring any jug with the spout "down", pour with the spout rotated 90 or 180 degrees.
When the jug is rotated, there is much more room for air to enter.
This works for oil and antifreeze gallon jugs especially well.
It also works on 5 gallon jugs.
Also, when an oil 5 quart container is poured when rotated, it is almost impossible to spill oil.
(The pour opening is MUCH closer to the hole you are pouring into)
Many times, you can pour oil directly into an engine fill opening, without a funnel.
It is AMAZING how much faster a container will empty when there is no glug, glug, glug happening
As the pour jug approaches being empty, you can rotate the pour spout back to the bottom, to finish emptying.
/ Pouring fuel from cans #9
I put the can in the loader bucket, raise it up and use one of those to get the fuel running.
/ Pouring fuel from cans #10
I keep my diesel in military Jerry cans along with a large diameter flexible metal nozzle. The can will empty in about three minuets. It's the lifting/holding of the full can that is most difficult.
/ Pouring fuel from cans #11
Or...... you can get one of these:
Works great, will pump a 5gal can in under 2 minutes. I made a little wheeled cart to move around. Only lift the can out of the truck.....
Here is the cart:2EE22BF4-638F-4825-9CA2-3705468BF766.jpeg
/ Pouring fuel from cans #12
Will gas or diesel destroy a rubber push in tire valve stem? Seeing the OP's solution with the metal cap, the tire valve stem came to mind. The push in stem may be easier to install then the OP's. Did not look for the installation instructions for the OP's Any thoughts? Jon
/ Pouring fuel from cans #13
I’ve had metal valve stem a a diesel can for like 5 years with no issues.
/ Pouring fuel from cans #15
The issue with a normal push in rubber valve stem is the typical plastic gas can isn't that thick and the surface where you'd put the stem typically has a seam and isn't flat. A normal stem may not seal. This is why the ones that the OP linked are screw together valves. They are also brass and presumably the seal on them is designed for gasoline.
Basically, you drill a hole. (I'm not clear on how you get the shavings out of a gas can that has had gas in it, myself) Then attach the stem to a wire and fish the stem into place from the inside. Screw the top on from the outside. Remove the wire.
The old gas cans had spouts that worked and had vents. There's no telling how much gas has been spilled because of incredibly stupid new mandated gas can spouts. Then they don't flow, and people end up having to find ways to vent them because the new gas can designs are so messed up.
/ Pouring fuel from cans #16
/ Pouring fuel from cans #17
I no longer have difficulty pouring from a can. Solution: when new and empty, I write the instructions on the bottom.
:D
Bruce
/ Pouring fuel from cans #18
/ Pouring fuel from cans #19
I don't use the slow pour spout, I simply pour from the jug into a big funnel stuck in the tank filler neck. I agree the new spouts are a pita.....
2014 F-150 STX (A56438)
2014 F-150 STX...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
CAT CB34 (A60462)
CAT CB34 (A60462)
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A61165)
2016 Hino 195h...
2008 KOMATSU PC200LC-8 HYDRAULIC EXCAVATOR (A64047)
2008 KOMATSU...
Harlo HP6500 (A60462)
