Posthole Digger Posthole auger point/bit replacement
/ Posthole auger point/bit replacement #1
beowulf
Veteran Member
Central California Foothills
Kubota L3410 HST, J Deere riding mower
The attachment that has proven to be the most disappointing has been my PHD. I have the Gearmore D40 with 6 and 9 inch augers. I almost always am using the 6 inch auger. The disappointment arises because - for whatever reason - unless the dirt is already soft enough to dig out with a manual post hole digger/shovel - frequently I cannot dig very deep. I am guessing it is not the PHD but rather the dirt here - we do have DG in places. So many times I will start to dig the holes with the PHD only to abandon the task and go about it by hand. BTW - most of the time I am aiming for abut 2' deep, more for some projects.
When I go to it by hand I can make progress - but slowly - by pounding away at the hard soil little by little. Sometimes after I make some progress I will try again with the PHD and sometimes it will work and sometimes I have to return to the manual method - and sometimes there I pour water and come back later. Only if the dirt is soft can I dig down with the PHD.
So, I am guessing that perhaps my auger point needs replacing. I found the replacement parts in the Gearmore PHD manual, but I also found some points at TSC. Those at TSC were of two kinds - a screw in kind and a bolt in kind. They do not match - visually at least - what I now have. But the design of the TSC replacement points seems superior to what I now have. I guess I will take off my points and to to TSC to see if the bolt on kind is the same size as what I have and if so will try it out. They are about $40. TSC has a new 6 inch auger for $129 which I guess I will get if their replacement points won't work on my auger.
Anyway, any suggestions re the best auger points? Anyone with experience with the TSC points vs the standard Gilmore points?
I was also thinking of grinding the ones I have to make them more effective, but like I said, I don't think the design is ideal. It just may be my soil.
/ Posthole auger point/bit replacement #2
I grind new points on my PHD
/ Posthole auger point/bit replacement #3
If the cutting blades OD is smaller then the auger OD it well not dig good.
/ Posthole auger point/bit replacement #4
My soil is mostly all hard packed red clay. It has a crust to it that is very hard to get though, but once I'm down a foot or two, it becomes easier. I have a full sized backhoe and during the heat of summer, I can hardly break through it.
On my 35 hp tractor, I started out with a Leinbaugh Line 12 inch post hole digger that was horrible. The cutting edge would just spin on the soil and never penetrate the hard soil. In Spring and Fall, it dug fine. After years of fighting it and trying to modify it with Pengo brand cutting teeth, I bought Speeco 12 auger bit that had replaceable teeth and a corkscrew tip.
This was night and day better. It would dig into the ground and usually go all the way down. I've learned that my soil is in layers, and there is a hardpan, gray colored layer of clay several feed down in areas. The Speeco bit would just wear away like it was hitting sand paper, and not dig anymore when it hit that gray stuff. After buying every replacement tip at both Atwoods stores in my area and then not having any more, or any idea of when more would arrive, I went to Tractor Supply and bought their Country Line 12 inch auger.
I've never been a fan of Tractor Supply, but I have to admit that this is the best digging, most aggressive auger that I've ever seen. It doesn't matter how dry the clay is, or if I hit that gray stuff, it just digs. I've had to relearn how to operate my post hole digger now because if I allow it to dig too fast, it will bury itself and bend the driveshaft.
So on another project I got the idea that I would buy a six inch auger from Tractor Supply. This one has proven to be more difficult to operate then the 12 inch. It's supper aggressive and I've destroyed two driveshafts burying it into the ground. I'm my worse enemy and I've developed the bad habit of revving the engine, slipping the clutch and getting the auger to spin itself out when buried in the ground. This is not only wearing out my clutch faster then normal, but it's bending those drive shafts a little every time it happens, until it looks like a bow that could shoot arrows.
Before I use it again with another brand new driveshaft, I'm going to weld on some feet to the boom of my auger that will not allow it to go down all the way to the ground when the auger buries itself. I'm just not smart enough or a good enough operator to not do this, so I need something that will limit how far down into the ground the auger will dig itself. Two feet on either side of the boom should do this. At least that's what I'm hoping for.
/ Posthole auger point/bit replacement #5
The cemented caliche out here is so hard that I've actually worn out a set of carbide teeth on my auger.
/ Posthole auger point/bit replacement #6
i started with a cheapo 3-point phd that would only dig is soft ground. Dry, hard ground and it would just spin and smoke. I bought some Danhuser (sp?) teeth and screw tip and installed them on the el-cheapo auger. Made a world of difference. Next, I bought a Lowe hydraulic phd. The standard teeth would wear out in our dry hard packed sandy soil or in our hard packed dry clay soil in about 20 holes. I then bought their carbide tips and put them on the outside of those augers that used 4 teeth per auger. All is well, they have held up. I recently bought a Shaver HD10 post pounder and that is the cats' meow, at least for putting in pipe posts. I have not tried it on a wood post yet.
/ Posthole auger point/bit replacement #7
I now have 2 nice Pengo augers. On the new 12" I had to flip the teeth after an hour or 2 as the teeth had worn. They were nice & sharp when I flipped them just beveled the wrong way. My replacement teeth will either be hard faced or carbide as the base ones are wearing to fast in the abrasive ground around here.
I also had a 200lbs chunk of steel from the junkyard mounted over my PHD gearbox. That extra downpressure really helps. But down pressure is no match for sharp teeth.
150ish holes completely wore out the teeth on my Speeco 12". I had to flip the teeth on my new 12" Pengo after 50ish holes. I'm guessing I'll get 1 more flip, maybe 2 before I'm replacing them. Teeth wear out fast.
/ Posthole auger point/bit replacement #8
I have about 175 holes with my TSC post hole digger. The last 10 or so it has had trouble starting the hole. The teeth are well worn. I'm going to replace them in the spring. I have lots of rocks and tree roots.
/ Posthole auger point/bit replacement #9
"It's supper aggressive and I've destroyed two driveshafts burying it into the ground."
Doesn't it have a shear bolt to keep from doing serious damage? Mine will snap the shear bolt first.
Thanks guys for all the responses. I see we have many of the same experiences - with our "dirt". I too have been able to bust through a hard layer by hand and then continue with the PHD effectively at times, but at other times that does not work as the soil is just too hard (typically with DG). I have tried water in the holes at times - letting it soak and coming back - sometimes works and sometimes it doesn't. Yesterday I tried out a new auger with the same results so it is the ground here. There are some areas where I can dig easily but unfortunately those areas are not always where I need the holes. Guess I have to live with it.
I have played around with where the PHD hooks up to the tractor but it appears only one combination of hook-ups gives me sufficient lift height so I can move the tractor around without it dragging or poking the auger into the ground on backing up.
/ Posthole auger point/bit replacement #11
I've snapped a few bolts when I hit something like a rock or a root, but when it's just digging deeper and deeper and I can't pull it out, it buries itself in the ground, and then either kills the engine, or eventually it can't go any deeper and I can slip the clutch and rev the engine enough to get it to spin in the hole and eventually break free. When it's that deep down, it bends the drive shaft. Probably ruining my clutch too.
/ Posthole auger point/bit replacement #12
What is your engine speed, I dig with engine around 1200 rpm, not sure of PTO speed. There is no need for full PTO speed to dig holes. If you ever see the power company put in poles their auger turns very slow.
/ Posthole auger point/bit replacement #13
I never really go above half throttle, usually not even that high when running my PHD.
/ Posthole auger point/bit replacement #14
Usually,,, for ME,
I have found that replacing the entire auger does not cost much more than just the point and teeth.
Other issues like wallowed shear pin hole, etc,,, go away as well.
New flighting just seems to dig MUCH better!! :thumbsup:
Usually,,, for ME,
That was how it worked out for me - it made more sense to get a new auger.
/ Posthole auger point/bit replacement #16
This was a dream hole fixing a sorry fence corner. About 20 seconds to get this, then spin it off, drop down two or so more times to clean out the hole.
/ Posthole auger point/bit replacement #17
I have a land pride. There are carbide tips available even on amazon. I replaced with a standard tip and changed the teeth at the end of the corkscrew portion. The teeth were worn round and I found they can be flipped for a more aggressive bite. Made a huge difference in my hard soil.
/ Posthole auger point/bit replacement #18
It's in that range. I go fast enough for it to dig and have the most uplift I can get to pull it out over and over again while digging. I only rev it up to the max when it buries itself in the bottom of the hole. Something that never happened with my previous augers, just the Country Line brand for Tractor Supply.
Power companies use hydraulic augers and they have a crane with both up and down pressure. When I've seen it done, they go straight down, then pull it up with the auger full of dirt, then they reverse it while it's in the air and the dirt falls off. I don't think there is any comparison between a 3 point auger and a hydraulic one. If you can afford it, that's going to be a thousand times better in every regard.
/ Posthole auger point/bit replacement #19
i bought the countyline phd with 9 inch auger then swapped to a 12. what eddie says about it burying itself is correct. i had it nearly corkscrew itself into the ground and i nearly panicked while trying to lift it up but it kept going into the ground. i was only going at 900-1400 rpm and was only touching 1/4 control the down control a little at a time. it only needs to grab a root or stone and it will literally tries to corkscrew down and lift the front end up a little on my little tractor. i just wait for it stop corkscrewing and then shut off the pto and lift it out. This way it will hold some of the dirt and i can spin most of dirt off by revving up the pto momentarily . try the tractor supply replacement tip on yours and see if it helps.
can you post a pic of your auger tip so i can compare it to mine? i would love the ability to swap from need to penetrate the soil to slowing down the corkscrew.
The only thing that stops me from drilling holes are always the rocks that protrudes halfway in middle of the hole when it snaps my shear bolts no matter how fast i try to shut off the pto.
/ Posthole auger point/bit replacement #20
My Pengo augers are only $4-5 each (times 4 teeth) for the basic teeth. Double that for hard faced teeth. Double again for carbide. I need to upgrade to hardfaced or carbide after seeing how fast my ground wears teeth.
The 12" Speeco (under $200) was $15ish each & needed 2 teeth. As the bolt holes to attach the auger to the PHD were tearing I upgraded to the beefier Pengo 12" ($350). Did end up getting new Speeco teeth & sold the 12" Speeco with my PHD & tractor. I kept my 9" & 12" Pengos. Have a spare PHD frame. Just need to get a gearbox, PTO shaft then chop up the frame to make it QH compatible again (requires a hydraulic toplink).
