Post-Purchase Depression and Upgraditis
   / Post-Purchase Depression and Upgraditis #41
I have had a BX2200 with loader and 60 inch mower for a few weeks now. I had thought of getting something slightly larger, but after using the BX2200 am glad I purchased the smaller tractor. I have 12 acres, 4 acres of fields, the rest woods. What convinced me was mowing along the pond at the rear of my property. Any tractor with a higher center of gravity would present a real problem given the slope of the banks. So far I am pleased with the tractor. The three point hitch is barely catagory 1 though. That might be an issue when I look for a small rotary cutter and rear blade. I'm hoping Kubta will resolve that issue.
   / Post-Purchase Depression and Upgraditis #42
Just a thought - couldn't you simply remove the lower arms of the 3 point, and replace them with arms from a B series tractor? Seems to me that would fix the "barely cat 1" issue for good, but am I looking at this too simplistically?
One 3ph experience is one too many.
I once removed my empty weight box from my BX. I could not spread the arms far enough to get it off unless I lengthened that turnbolt thing on the variable length coupling. (It's not even a turnbuckle, which themselves are horribly klutzie.) Then there were the 15th century cotter pins that you can't open or close. And all I was doing was the easier process (removal) of a very light weight implement.
That's enough for me. I could easily foresee crowbars, mauls, tugging, yanking and inury in my 3ph future. As far as I am concerned, the tractor industry should be ashamed of itself for developing nothing better after 85 years than the 3ph. It should get the mega-spinach award for the worst interface ever developed.
If this Connecticut yankee is gonna spend $15-$20K, or eventually more, on tractor stuff, you can bet that Freedom Hitches are and will be an essential part of the budget.
Glenn
   / Post-Purchase Depression and Upgraditis #44
The 3 point hitch wasn't on my Dad's tractor that we go in the mid 50's. The ONLY lift mechanism on it was gear driven lift for a plow. You had to crank it, because it did not have a starter or battery. All other implements were pulled. Granted that was 45 years ago, but most of the 3 point mechanisms of today are really first class. We average changing an implement or two every 4 to 6 hours and the total operation takes about 5 minutes. My tractor has the adjustable 3 point links and a hydraulic top link, but I wouldn't give a dime for a freedom hitch, but recongnize that there are those that do.
It normall works like this. Back up to a mower. Remove a clip and pin if they are in the tight position, slip the lower 3 point ends over the mower pins. Punch the upper hydraulic link, slip the pin through it and pin it. Set the brakes on the tractor and push the pto shaft on until it clicks. With the freedom hitch, the pto shaft must still be coupled and that takes as much time as the 3 point pins.
Now this is not a BX, I am talking about, but it sure works well and is easy to couple. No crowbar, no sledgehammer, and I can take 5 minutes to put on an implement that I will be using for 4 to 12 hours at a time.
   / Post-Purchase Depression and Upgraditis #45
I'm still watching from the bleachers here, but is there any merit to the DeltaHook 3Pt quick attach adapter that appears in the Gearmore catalog? It looks like this. I will post the specs if it will help.
Wen, we come at tractoring from different life experiences. You apparently grew up with them. They are new to me.
I understand from reading and from some very old dealerships here in Connecticut that, originally, each tractor manufacturer had its own connection scheme for its own implements. Sort of like you can't run Apple computer programs on IBM hardware. Then, in about the 1960's, standards organizations standardized on the various 3ph categories. So, I am sure that the 3ph was an improvement. But once anything gets standardized, it is always hard to change the standard even when something better comes along.
I have paddled canoes for 50 years, and enjoy paddling in some old boats that new participants in the sport would sneer at. It's part of my life experience. (Of course, little do they know that I have 11 other boats, including the hottest new models.)
I have a 110 mile commute each day, have only the weekends to tractor, and don't want to spend all my free time doing it. I see the larger issue of removing and mounting all the heavy implements (3ph, FEL, mid-mower) as being a significant deterrent to using those very implements. So, when I see a product that allows you to attach or detach in 5 seconds--not counting PTO shaft, as you point out--I see that device as worthy of 5% of my tractor budget. Plus, it adds about 110 lbs of rear counterweight.
But mostly, I guess, I have none of my personal history invested in 3 point hitching--as I do in wooden canoes, for example--so I simply choose not to get involved in something that, to me, is inferior technology.
   / Post-Purchase Depression and Upgraditis #47
3 pt hitch Disgust
Wen, in your comment about just removing the arms off the pins...
He may only have the BX to use has his 3pt example. If I didn't have another tractor here that has been used with 3pt implements, (Ford 1710) I would be extremely frustrated with it as well.
On the Ford you just slip the arms off easy as pie. Quick, easy, no fuss no muss, like you said, minutes.
On the BX you CAN'T spread the arms out to get them off outward facing pins, even with the chains off. I cannot spread the link off of the pin. (I threw out the goofball cotters and just put little finger snap locks (my term) in them for speed) I have to pull the safety pin then force the implement sideways out of the arm. It is completely bizarre. The BX may meet the legal requirements of being a Cat 1 but in all seriousness, I would love to have the designer(s) time for a day. I would like to see them put this Cat 1 rake on and off this BX over and over and over and over. And they can put on their "upgrade" which I do not think is going to solve the problem.
And as another fellow posted, why can't the arms of the B75 or B2410 be used? I wonder, it would probably be closer than the link arms off of my Ford or L35 which I am probably going to try.
There are a dealers reading this forum (quietly, lurking in the background) I would like to address each of them and ask that they go out and check this for themselves. I would also humbly suggest that if they are telling people this is a CAT 1 hitch they might want to consider taking cover when the buyer gets a belly full of dealing with it.
As I mentioned, it probably is LEGALLY a three point hitch but it is a huge problem compared to a "typical" 3pt. As I mentioned in another post, when the links are attached to an implement the lower arms are completely spread to the point that the sockets are at the extreme maximum of movement, rendering them worthless as a pivot. If I didn't have a backhoe here with a chain hook on it to hold up implements and move them around I don't know what I'd do.
And I don't agree with the other fellows suggestion to use Cat 0 implements. No offense meant, but the CAT 0 implements I have seen are designed for 2WD garden tractors and would probably bend in half if they caught on a rock even with the BX pulling them. The whole business of using a CAT 1 implement IS being able to have the advantage of using them between different tractors, and also having the benefit of finding them anywhere.
del
[email]oldcarparts@mygarage.com [/email]
   / Post-Purchase Depression and Upgraditis #48
I've seen those freedom type hitches (some big JD's come with some type already). They seem to work great.
All BX's should come with them!
The disadvantage is they seem to push the load out farther back, you have a limited lift capability and even if you can still lift the implement you are still hanging more load on the back then necessary. Sometimes this helps your work, but can also make steering a problem if you are hoping just front end weights (no loader) are going to hold you down. The other problem is that if it is a freedom hitch that has outward pins there is still a problem as the lower link arms are jammed so far outward that they really look like they are going to have a short life, especially the pins on the tractor end!
This type of setup is used on a lot of big construction equipment, I watched a guy with a big excavator change is bucket back and forth from his seat! I want that! Six inch backhoe bucket...OK now 36 inch bucket!
   / Post-Purchase Depression and Upgraditis #49
The quick change hitches are an up and coming market. Why you ask---LABOR COSTS AND SAFTY---. If a landscape company that changes 3pt implements often it can pay for itself not only in timesavings but also the safty of not having to get off the tractor unless you have to hook up a pto shaft.
Now to someone who has been hooking up 3pt's for a long time it might not seem to be worth it. But think of the college kid who has a summer job landscaping and look at it from a bosses perspective. Just from the labor savings alone it pays for itself real quick---thats not even taking into account the hassle factor of hooking up.
If I could afford a freedom I'd have one!!!/w3tcompact/icons/smile.gif
Gordon
   / Post-Purchase Depression and Upgraditis #50
Harv, that design is the same one that freedom hitch uses. I got the freedom hitch video and I would buy one if it wasn't so expensive. The problem is you have to buy a tractor part (one) and then another part for each implement you have. At about $200 for the implement part that adds up. If I made my living at it it would be a no brainer. As far as hooking up an implement in 5 minutes I'm skeptical depending on the implement. My rake, no problem, I can horse it around. My cutter, same thing since the pin portion has some movement. My 5 ft box blade with added weight - forget it. If you're not on perfectly level ground you have to futz around some raising and lowering the 3 pt to get both sides to match up. (The top links the easy part) I'll probably break down some day and get the freedom hitch and then kick myself for witing so long. Anyway I have to agree, the current 3pts are a poor design and could be greatyl improved for hook ups similar to those used on skidsteers. They can just drive into something and pick it up and they have probably 20 different implements designed to attach that way.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
