Post-Purchase Depression and Upgraditis
   / Post-Purchase Depression and Upgraditis #31
Yeah, you are doing better now. You have one misconception, though and I am not suggesting my tractor to you. My M6800 will work all day better in the creek because it has very large tires and enough weigh/sq ft to push the ag treads into the creek to get traction, 4WD and when you have something in the bucket, I can do something with it. The large tires span small ditches and it will go where a smaller tractor can't.
Always look at both the weight of the tractor AND the size tires on it as well as the HP to determine the type work it can do. Many larger tractors do not compress the soil any more than smaller ones - all depends on the square inches of tires in contact with the ground.
   / Post-Purchase Depression and Upgraditis #32
Glennmac,
Sure can be hard to buy new tool/toys these days. In reading your posts, I was wondering what your snow removal needs would be? No one is thinking about snow down here in the south, but, yours is right around the corner.
You are the only one who can evaluate your maneuverabiliy needs so size may be the main consideration. I know a lot of finish mowing is done with tractors in the 2910 range and larger. Many of us have found that a new tractor opens up so many more projects than we thought we would take on, larger seems to work better. Guess you have already seen some of that. I wonder if the larger tractor with turf tires might not work best. For your wet areas, turfs may not be the best although chains for snow and mud area developement or the extra wide turfs work for others on the forum.
Just my thoughts to help add a few more clouds to the issue.
MarkV
Wen and MarkV are raising a tire issue that I may have wrong. About 3 of my acres are wettish. Standing water ponds up in some areas after rains. Even when "dry" the soil is always softish. My BX bar turf tires would spin out under the light loader stress and dig ruts. I always could get out with the 4wd, but what a mess. (This summer has been unusually wet, however).
I have been assuming that I need a very aggressive tread (ie, r4 industrial; i will no go to ags) are what I need near the creek. Are either of you suggesting that wide turfs are better that r4's? Do you mean they will sink in less, or bite the same, or float the tractor higher (even a heavier tractor)? Or what? Now I'm unsure of what tires for wet-prone, softish, moist land.........Glenn
   / Post-Purchase Depression and Upgraditis #34
Glenmac,
I was in the same boat as you, 1.5 ac finish grass, 9 acres field/pasture. Bottom line was I could get a small lawn tractor for the finish grass cheaper than I could buy a 3pt finish mower ($1300 for a riding hydro mower vs $1500 for a finish mower) By going larger I got the option of doing a lot of things I couldn't do as well with a smaller machine and could get R1 tires without worrying about damaging the grass. I wouldn't want to do field mowing with turfs or anything that required a lot of traction. The one machine fits all concept just doesn't work well.
Gerard, your logic is impeccable and it reminds me of my initial goal: to get a motorized machine to mow my lawn. A lawn tractor. Then it became: mow the creek area. Then it became: why not a 3ph to do some other things occasionally. Then it became: why not a cool loader. Thus was born the BX.
All of a sudden I'm seriously thinking of buying a machine to terraform the planet, requiring me to buy the original lawn tractor, but now as second machine, to mow my lawn.
I must remember my original focus.
   / Post-Purchase Depression and Upgraditis #36
Ken - as you are not registered I can not send this via private message, so I hope you will see this post. I also have a B1700, and absolutely love everything about it EXCEPT its relative unsteadiness on slopes. Just bought a tiltmeter (will post on my experiences with it after some more hours) which has helped, but just looking at the 2 machines side by side I would think the BVX is more stable than the 1700, as it is lower, with almost the same weight. Any comments on the stabiility of the 2 tractors from someone who has owned both?
   / Post-Purchase Depression and Upgraditis #37
A few more thoughts...
I believe the B2410 does still offer the Bi-Speed turn option for the extra maneuverability (the B2710/2910 doesn't).
Whenever you buy, it sounds like you could use a set of turf tires and a set of Ag tires. I wonder if a set of Ag tires for your BX would help things?
   / Post-Purchase Depression and Upgraditis #38
Paul,
I guess I've just been lazy about logging on. Actually I have been a regular at this site for about three years. I actually won a Kubota hat from Muhammad back when the site was a Kubota only web site.
So you own a B1700. I loved mine but it was more machine than I needed. I did have one incident where I almost tipped it over on its side. I was hauling the 72' Landpride rear blade with the bucket loader and I had the bucket raised for clearance. My bucket had 2 hooks that I had the dealer install when I purchased it. One on either side. I had the rear blade chained to the right side bucket hook. I was trying to get by my Explorer and the ground was uneven sloping up on my left. As the tractor started to engage the tilting grade the blade swung to the right and the tractor pitched to the side almost throwing me off the tractor. In fact I thought it was going over and I am looking at my brand new 99 explorer and thinking "oh s--t".
Well it didn't go over and the blade didn't swing into the Explorer but it sure wised me up to the tipsiness of a tractor with the bucket raised.
My B1700 had loaded rear wheels which I think is a must if you have a bucket loader. I do think that the B1700 does need to be carefully maneuvered on slopes. The BX2200 (36 hours) that I now own has loaded rear wheels and my experience with it to date has been that it is much more stable on slopes than the B1700. Actually the additional 5 hp somewhat compensates for the loss in traction due to the smaller rear loaded tires.
I have been moving some large rocks on my property for a shed I am building. Picked on up with the BX2200 loader that was just about the limit of the lifting weight capacity (460#) of the machine. The tractor was just on the verge of lifting the rear wheels off the ground all through the transport of the rock. I decided that I am going to add the wheel weights because of this experience. I also bought one of the R&B manufacturing tilt meters to keep me honest about how much tilt I am experiencing. I haven't installed it yet as I am waiting till the Chappel Tractor installs the Curtis Cab I bought with the tractor. It should be soon.
Oh, and I am a lot more serious about the seat belt usage now based on these experiences. I just wish that they didn't keep tightening down on you in the seat so much. I think that with the added rear wheel weights and the 5 hp that the BX2200 will approach close to the B1700 in pushing capability. It will never have the LA301 loader’s lifting capability. I hope this info helps. I would be interested in hearing your "war" stories.
Best Regards,
Ken Johnson
<P ID="edit"><FONT SIZE=-1>Edited by kj33 on 9/1/00 09:42 AM.</FONT></P>
   / Post-Purchase Depression and Upgraditis #39
Ken - thanks for the post. For my most celebrated war story search the archives for "Up on 2 wheels...need new underwear". that was me. I don't truly fear a tipover now that I have a couple of years experience with my tractor on my land, but I do hate the general feeling of terror that accompanies almost every time I use the tractor on any slope at all - just a general feeling of unsteadiness. I do not have this feeling using my garden tractor on slopes WAY more steep than I would EVER take the kubota on, and I attribute this to the lower stance of the garden tractor. Hence my interest in the BX. I may ask my dealer to let me demo one on my land. If the stability were that much better, I might be willing to give up some hydraulic power (no big deal) and the position control (really big deal), but I would have to be absolutely sure that the safety improvement outweighed what I am sure would be some loss of capability.
Click, click, click. The ratchet must stop. The die must be cast. The Rubicon must be crossed.
I am the king of vacillation. I have read and re-read all your posts, and I truly appreciate all the advice and encouragement I have gotten about whether I should trade the BX and what I should replace it with. I was at the dealer after hours in the dark and rain last night with my headlights shining on the line of B's and Grand L's, with me climbing on and off wet tractors for the nth time.
It is now time to shut off this computer, go downstairs, put the BX in my shirt pocket and order my replacement machine from my patient dealer, or tell him I'm keeping it. I am not going to say what I am planning to do. Mainly so I can preserve my freedom to change my mind six more times on the four mile drive to the dealer.
You may have noticed that shortly before I started this Depression topic, I started one called the Guiness Machine, asking about the biggest tractor in the world. On the other hand, I have grown very fond of my cute little BX. I even park it on my front lawn outside my bedroom window so I can look at it day and night. There it is out there right now. I will miss it. Maybe ...
Click, click, cli ...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
