Post Hole Digger
/ Post Hole Digger #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I know that gravely made post hole diggers back in the day, does anyone make them for today's walk behinds?
/ Post Hole Digger #2
Digging post holes with a Gravely just isn't possible. Of course that depends on how a post hole is defined. If it is defined as a hole 6-8 in diameter, 2-4 ft deep, then the Gravely won't do it. Period. Just rent a two man post hole digger. Now if you want to plant some shrubs, then that is a different matter.
/ Post Hole Digger
I am looking at 1 foot deep, only about 4 inch diameter
/ Post Hole Digger #4
Why not make your self a small digger with a hyd motor and a cut down auger, and put a hyd pump on the engine if possible. Those hyd motors have the torque through out the rpm range of the motor.
I used a small gas portable drill, with a spade bit the size of a one gal pot, and dug many hundreds of holes. About 10 sec per hole .
Maybe something like this.
http://www.wikco.com/easyauger.html
/ Post Hole Digger
Great idea. Thanks.
Where can I get a hydraulic auger head cheap for this project?
/ Post Hole Digger
I am hoping to reduce the amount of engines I have... but I am leaning that way
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 John Deere R-4038 (A63688)
2019 John Deere...
11R22.5 ALUMINUM WHEELS AND TIRES (A63569)
11R22.5 ALUMINUM...
KBH Fertilizer Rig (A64047)
KBH Fertilizer Rig...
