Post Hole Digger
/ Post Hole Digger #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I know that gravely made post hole diggers back in the day, does anyone make them for today's walk behinds?
/ Post Hole Digger #2
Digging post holes with a Gravely just isn't possible. Of course that depends on how a post hole is defined. If it is defined as a hole 6-8 in diameter, 2-4 ft deep, then the Gravely won't do it. Period. Just rent a two man post hole digger. Now if you want to plant some shrubs, then that is a different matter.
/ Post Hole Digger
I am looking at 1 foot deep, only about 4 inch diameter
/ Post Hole Digger #4
Why not make your self a small digger with a hyd motor and a cut down auger, and put a hyd pump on the engine if possible. Those hyd motors have the torque through out the rpm range of the motor.
I used a small gas portable drill, with a spade bit the size of a one gal pot, and dug many hundreds of holes. About 10 sec per hole .
Maybe something like this.
http://www.wikco.com/easyauger.html
/ Post Hole Digger
Great idea. Thanks.
Where can I get a hydraulic auger head cheap for this project?
/ Post Hole Digger
I am hoping to reduce the amount of engines I have... but I am leaning that way
2021 Kubota MX5400 (A60462)
2021 Kubota MX5400...
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
Metal Drop Box (A59317)
Metal Drop Box...
2016 FORD F-450 (A60736)
2016 FORD F-450...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
