Post Hole Digger
/ Post Hole Digger #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I know that gravely made post hole diggers back in the day, does anyone make them for today's walk behinds?
/ Post Hole Digger #2
Digging post holes with a Gravely just isn't possible. Of course that depends on how a post hole is defined. If it is defined as a hole 6-8 in diameter, 2-4 ft deep, then the Gravely won't do it. Period. Just rent a two man post hole digger. Now if you want to plant some shrubs, then that is a different matter.
/ Post Hole Digger
I am looking at 1 foot deep, only about 4 inch diameter
/ Post Hole Digger #4
Why not make your self a small digger with a hyd motor and a cut down auger, and put a hyd pump on the engine if possible. Those hyd motors have the torque through out the rpm range of the motor.
I used a small gas portable drill, with a spade bit the size of a one gal pot, and dug many hundreds of holes. About 10 sec per hole .
Maybe something like this.
http://www.wikco.com/easyauger.html
/ Post Hole Digger
Great idea. Thanks.
Where can I get a hydraulic auger head cheap for this project?
/ Post Hole Digger
I am hoping to reduce the amount of engines I have... but I am leaning that way
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2023 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2023 Posi Track...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
