Post Hole Digger
/ Post Hole Digger #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I know that gravely made post hole diggers back in the day, does anyone make them for today's walk behinds?
/ Post Hole Digger #2
Digging post holes with a Gravely just isn't possible. Of course that depends on how a post hole is defined. If it is defined as a hole 6-8 in diameter, 2-4 ft deep, then the Gravely won't do it. Period. Just rent a two man post hole digger. Now if you want to plant some shrubs, then that is a different matter.
/ Post Hole Digger
I am looking at 1 foot deep, only about 4 inch diameter
/ Post Hole Digger #4
Why not make your self a small digger with a hyd motor and a cut down auger, and put a hyd pump on the engine if possible. Those hyd motors have the torque through out the rpm range of the motor.
I used a small gas portable drill, with a spade bit the size of a one gal pot, and dug many hundreds of holes. About 10 sec per hole .
Maybe something like this.
http://www.wikco.com/easyauger.html
/ Post Hole Digger
Great idea. Thanks.
Where can I get a hydraulic auger head cheap for this project?
/ Post Hole Digger
I am hoping to reduce the amount of engines I have... but I am leaning that way
2009 Kubota M108S (A60462)
2009 Kubota M108S...
SKIDDED PLAIN/WASTE WATER TANK (A63569)
SKIDDED...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Patterson water pump (A59230)
Patterson water...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2005 International 4400 Truck (A61573)
2005 International...
