Post Hole Digger
/ Post Hole Digger #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I know that gravely made post hole diggers back in the day, does anyone make them for today's walk behinds?
/ Post Hole Digger #2
Digging post holes with a Gravely just isn't possible. Of course that depends on how a post hole is defined. If it is defined as a hole 6-8 in diameter, 2-4 ft deep, then the Gravely won't do it. Period. Just rent a two man post hole digger. Now if you want to plant some shrubs, then that is a different matter.
/ Post Hole Digger
I am looking at 1 foot deep, only about 4 inch diameter
/ Post Hole Digger #4
Why not make your self a small digger with a hyd motor and a cut down auger, and put a hyd pump on the engine if possible. Those hyd motors have the torque through out the rpm range of the motor.
I used a small gas portable drill, with a spade bit the size of a one gal pot, and dug many hundreds of holes. About 10 sec per hole .
Maybe something like this.
http://www.wikco.com/easyauger.html
/ Post Hole Digger
Great idea. Thanks.
Where can I get a hydraulic auger head cheap for this project?
/ Post Hole Digger
I am hoping to reduce the amount of engines I have... but I am leaning that way
2014 WESTERN STAR 4900 SF (A60736)
2014 WESTERN STAR...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
