Post hole digger stand
/ Post hole digger stand #21
That may work out if the hole doesn't keep water in. I may try it if it ever dries out around here. /forums/images/graemlins/frown.gif
Kioti Orange.
I thoroughly agree about the lower the better point, but in our area here, and especially on the property we rent. We do not call the fence post's Posts, we call them plugs cause we put them in the hole to keep the water from coming out of the ground.
During springtime, it would be under water most of the time.
Great thought but I do not think it will work in my circumustance.
/ Post hole digger stand #23
creeper,
I understand that. My thought was that the gravel would (hopefully) allow rainwater drain out, or at least stay low enough so as not to fill the hole. The VA soil (if you want to call it that) doesn't perc so well, so I imagine if it doesn't get in from above it may be alright.
I may have to experiment myself some day and pass it along.
KiotiOrange
/ Post hole digger stand #25
That works. /forums/images/graemlins/wink.gif
/ Post hole digger stand #26
AlanB said:
Has anyone made, or seen, or have a photograph, of a stand for a standard type post hole digger that holds it in position to hook up too the tractor?
my stand
/ Post hole digger stand #27
ns,I have the exact digger you have but can't identify it.Do you know who makes it?I bent the curved pipe bottom piece into a pretzel and need to buy a new one. Thanks.
/ Post hole digger stand #29
I just looked & did not find the paperwork on it. Will look for indentifying info on it when I am out where it is stored.
We purchased it in 1972, along with a new Little Rhino blade & used David Brown 770 tractor. I found paper work on them, but not the post hole digger.
/ Post hole digger stand #31
Being an organic kind of guy...I let my PHD stand grow by itself...less effort than building one...:)
/ Post hole digger stand #32
Hi Bones1,
My digger is a Servis Brand, Model GSD, I bought it new, I think in 1972.
/ Post hole digger stand #33
Hey Bill, you stole my patent.;) That stand looks just like mine.:D
...and the holder for your beer ain't bad either.:rolleyes:
/ Post hole digger stand #34
Here is my simple solution for an auger stand. If you control the auger bit, the PHD can be easily mounted and unmounted. Most frame-type supports are too complicated, and cost almost as much as the post hole digger. This is made of 1/2" steel pipe, welded to a diamond plate base. You could easily put this on a dolly if space is tight in your shop. I have a large implement shed, so I wanted mine in a fixed location. I used to struggle holding the PHD upright to hook it up, but now it's a breaze. I have used this Rankin 9" PHD 301 for years and have drilled hundreds of holes. The stand really helps.
/ Post hole digger stand #35
One of the problems with this type of stand is that you always have to have one size auger on it. Sort of a pain if you use different size augers. If you only have one size auger, no problem.
/ Post hole digger stand #36
You might of seen this before, but here is mine. The front leg screws up and down to line it up. Real easy and safe. The post hole digger was the hardest 3pt to hook up that I have.
/ Post hole digger stand #37
Check out the Bush Hog parking stand for their PHD. I have one for my 1202 Bush Hog PHD. $135.00 for the parking stand if I remember correctly. It's plug and play so to speak. Back up and insert three pins. Nothing to touch except the three pins. On or off.
/ Post hole digger stand #38
I'm sure that this works good, but isn't it a hassle to always have to remove the auger before parking the PHD?
/ Post hole digger stand #39
No, more then likely it wouldn't be the size I need to use anyway. Only two bolts. I make up the time for that when hooking up.
/ Post hole digger stand #40
I only use a 9" auger. For me that is a great all-purpose size for fence post holes and deck footings. If I had multiple bits, I would just make another stand to store it in. If you need it mobile, just put the hole thing on a dolly.
Thanks for the good ideas everyone.
Best of Luck!
Wolverine SWDB-11-84W 84" QA Angle Blade (A64912)
Wolverine...
PORTA POTTY (A67714)
Isuzu 4 Cylinder Motor (A64912)
Isuzu 4 Cylinder...
TORO SGR-13 STUMP GRINDER (A67714)
TORO SGR-13 STUMP...
2014 FORD F-150 (A67714)
2014 FORD F-150...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
