Posthole Digger Post hole auger PTO attachment question
/ Post hole auger PTO attachment question #1
jpat34721
Sonoma County (California Wine Country)
MF 1260
I bought a used tractor a few years back that came with a post hole auger which I am just now hooking up for the first time. The problem I'm having is that the drive shaft doesn't reach the PTO shaft (it's about 18" short). I'm wondering if the auiger drive shaft needs to be extended (it won't budge, rust I suppose) or if I need some sort of extension shaft that connects to the PTO and the the PH digger drive shaft attaches to that. If it's the former, any hints on getting rusted extendable drive shafts to budge? Also, I can't get the universal joint of the drive shaft off the auger head so any help there would be appreciated as well.
Thanks,
Jeff
/ Post hole auger PTO attachment question #2
all auger shafts should be extendable types. they have to be able to slide in and out as the units lowers into the ground. yours is probably frozen ((rusted) inplace.
/ Post hole auger PTO attachment question #3
Take some ATF and Kerosene (50/50 mix) or J&B rust buster. Keep trying to get the mixture into the two shafts, one slides into the other. Tap lightly, I said lightly, around the outer shaft housing. May try to add some heat. Take your time and it should come loose. The outer shaft housing should be towards the PTO so when it is detached you can chain it up ^ so rain doesn't flow into it and cause this same problem. There should also be a grease zesty on the outer shaft housing for greasing: about 5 pumps or so on a regular usage basis. That ought to do it. Happy New Year
Thanks for the tips guys. Once I knew it was supposed to slip (thanks grsthegreat ) I chained it to my draw bar and broke it loose with my rear lift arms. Greased it up and it slides smooth now. :) I'll try the J&B to get the universal joint free from the auger spline.
/ Post hole auger PTO attachment question #5
good to hear....good luck
/ Post hole auger PTO attachment question #6
Get yourself some Kano Kroil if you don't have any. It's a miracle product for breaking free stuff that's rusted together.
/ Post hole auger PTO attachment question #7
If you are removing the pto universal joint from the smaller input shaft of the drive head, you should look for that connection to be the shear pin safety point for the drive head. Typically, I would expect the bolt through the universal and the input shaft to shear upon overload. The universal joint then spins freely on the shaft and is allowed to spin with either a hex set screw or roll pin engaging a groove in the input shaft. Besides the shear bolt holes in the universal, look for either a set screw (one hole) or a roll pin (two holes), which will need to be loosened or removed to remove the driveshaft. The other options would be a shear pin at the tractor end of the pto shaft or a slip clutch somewhere. Mine was a roll pin and was an absolute bear to remove. Good luck.
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
