Positive ground generator/welder
/ Positive ground generator/welder #1
I just bought an old "AIRCO" engine driven welder generator. It is old enough that it has a "positive ground" battery starter/ignition. Two cylinder ONAN gas engine. 350 amps DC welder, 110 volt - 220 volt AC generator, 110 volt DC generator (45.5 AMPs at 110 volts, 10 KW nameplate rating).
I bought it primarly to run my well during power outages.
I did not realize that the ignition/starter circuit was positive ground and of course, it may make no difference at all.
I do realize the the 220 (240) volt circuit does not use "ground" as part of the circuit
My concern is - if I ground the generator frame to earth (mechanical ground) as my neighbor has with his generator, will there be any adverse results?
Thanks,
Rose is Rose
/ Positive ground generator/welder #2
I think you will be all right grounding the chassis. After all, what you are protecting against is case where the generator voltage (which is a/c) gets on the chassis, which would create a voltage potential to earth ground. The positive ground of the starting circuit is not factor at that point.
/ Positive ground generator/welder #3
No problem grounding the chassis. These are two different circuits, the DC engine system and the AC generator/welder circuit. A/C (alternating current) does not have a - or +, only hots and neutral/ground.
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
TREBRO 5C2010 SOD CUTTER / HARVESTER (A63291)
TREBRO 5C2010 SOD...
EAGLE FIBERGLASS BOAT (A63291)
EAGLE FIBERGLASS...
(1) UNUSED 12.4-16 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12.4-16...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
