posi lock wont engage
/ posi lock wont engage #1
titan307
yanmar ym1500
the other day i was doing some box work and when i went to step on the posi lock pedal the posi would not engage? is there a clip or pin inside i need to fix? how hard is it to fix this problem? what might i get into when i tear into it?
/ posi lock wont engage #2
What kind of tractor do you have? And what model?
Mark
***edit*** Ok, I see it's a YM1500. It may be a broken roll pin or you may have to remove the hydraulic lift assembly to see if the shaft is broken....It's not too bad of a job and parts are readily avialable.
thanks for the reply. im thinking roll pin because sometimes it will work.
/ posi lock wont engage #4
Somtimes on my 1700 it take a revolution or 2 of the wheels before it engages.
/ posi lock wont engage #5
Actually.. if it works sometimes.. I'd look for other problems than a sheared pin.. if the pin was sheared off.. it would not work at all.
Is the shaft binding any?
Soundguy
yes it does seem hard to push the pedal (at times) other time it pushes easily but still doesnt engage.
/ posi lock wont engage #7
I was thinking the same thing about the roll pin. It may be as simple as rust/crud inhibiting the travel of the spring and shaft to the bull gear, or binding on the case without lubrication.
Mark
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
John Deere HX15 Batwing Mower (A64047)
John Deere HX15...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
TRANSFER PUMPS ON SKID (A63569)
TRANSFER PUMPS ON...
WACKER NEUSON LIGHT TOWER (A63569)
WACKER NEUSON...
ALUMINUM TOOL BOX (A63569)
ALUMINUM TOOL BOX...
