Portable water heater!
   / Portable water heater! #1
moored4
Veteran Member
Great NorthWest /Southwest Washington
Kubota l245dt, l3540, 8N
We are setting up a hot tub inside a wilderness area on private property. We are cutting the oak barrel stays and the steel ring to keep it all together pre assembling it and then we will disassemble it all, cause everything has to be carried in 20+ miles on horse and mule back.
We need ideals on how to heat 12 to 1500 gallons of mountain spring water in a reasonable time period (1 hour or so) using wood.
Thanks for all of the Good ideals inadvance.:thumbsup:
   / Portable water heater! #2
Do you have a way to run a small pump to fill a water heater tank? I'm thinking a 3/8" copper coil on the stove running to a hot water heater tank placed higher than the coil. Hot water rises, cold water sinks. Be sure the water heater has a pressure release valve that works, don't want to make a bomb.
   / Portable water heater! #4
You better be doing some math. You are talking some serious BTUs to get that much water hot that fast. It will take a while to get the fire going big enough to heat that much water. It will take a pretty good size coil also to transfer the heat that fast.
   / Portable water heater! #5
BTU = energy required to heat 1lb of water 1 degree F.
1500 Gallons x 8.3 lbs = 12,450 lbs
Lets assume you have cold mountain spring water at 50 and need to get it to 100F for the spa.
Increase temp by 50 degrees.
You need to put +/- 625,000 BTU's into the water.
A REALLY big heat your house kind of wood stove is in the 80-100K BTU range... and You could never capture 100% of the wood stove's heat, and the water is giving off heat to the air as you are trying to heat it up...
So either you will need enough wood burning that the Russians would mistake it for an ICBM launch, or you need to adjust your time to heat, or heat fewer gallons.
The way we did it back in the day, was a few old 500 Gal propane tanks cut in half. The closed end of the tank had a smoke stack cut/welded into it, and the big open end was outside the tub.
We then built a BIG fire inside the tanks and it still took about a day to heat the tub up, but we were dealing with a 30' wide, 4' deep tub. Once it got up to temp we could cut back on the number and intensity of the fires, but it took a lot of wood and a lot of time to get the water heated up.
   / Portable water heater! #7
1500 gal is a HUGE hot tub. my 8 man tub only takes 500 gallons. You must like to party......
I Redid the math and it's 1200 gallons. The time is not an exact number, we just want hot water so our visitors can rest and soak after ridding horse and rafting all day. The camp cook can start the fire sometime during the day! The system has to be portable by horse back and we have no electrical power to use for it! Lots a squaw wood around!:)
PS: Want to keep it as cheap as we can also cause during the winter who knows what could happen to it!
   / Portable water heater! #9
I built a fire box one time that fit over in the side of a hot tub. It was a top fill and to get the air at the fire I bent a steel pipe and weded it in the bottom of my fire box. THe flue was on the side of the box at the top. It worked good but was a pain to scoop out the ashes from the top. The outside was stipped with wood to avoid contact to skin.
I have a water heater I made from a 55 gallon drum with a 3 inch exhaust pipe welded all the way through it. I welded a fitting on the bottom and one on the top to accept garden hose and other fittings. I have a T&P valve on the top. THe pipe extends 4 inches out each end of the 55 gallon drum. I have a half a steel 55 gallon drum that I burnt a 3 inch hole in the top. The pipe will fit in it and and I build a fire in the bottom tank and it will heat up pretty fast. Ive used this a few times when the Gas water heater broke and during other emergencies.
   / Portable water heater! #10
Use to go camping at Mt Baker, had natural hot springs.
mark
   / Portable water heater! #11
This probably has nothing to do with the OP except it reminded me of a TV show I saw where these guys were trying to build a copy of a Roman spa that was fired by wood. By the end of the show, they had gained more respect for Roman building methods and even thought it was fairly efficient.
Today's water heaters have temperature and pressure relief valves and thermostatic controls to limit the water temperature so the heater doesn't go above 212 F, become a boiler and blow up. If you're heating water in an open container, that's one thing. But if you heat it in an enclosed vessel, better be careful.
   / Portable water heater! #12
Thsi would work. Don't forget the carrort and tators
   / Portable water heater! #14
Have you considered a steam bath. It might be much quicker.:)
lets see 500 gallon tub is = to a little over 200 cubic feet =when you counsider a 3 foot depth then the tub would be 8'x8' or 64 sq. feet for 8 men-that's 8sq feet per man, thats a area of 4'x2'! That is a little close for me! I ll stick to our 1200 gallon thank you! 8 men in a tub 'rub a dub dub'! It's You who must like to party:laughing:
Yes we have one like that that we can heat a 5 gallon bucket of water with. It works great but on the larger scale we thought it wood load up to quick with ash!:)
   / Portable water heater! #18
Have you considered at tankless propane water heater?
Deluxe Tankless Water Heater
Like, except with more power for campers, cabins, sheds and more.
?0コ to 165コF adjustable water temp
?.65 gallons per minute, enough to feed a shower and sink at the same time
å§«ermanent installation (can't mount on vinyl siding)
百tainless steel rain cap
?' regulator
æ¡§ne 20-lb. propane tank provides up to 12 hrs. of use when filled.
ç*†easures 32 x 14 x 8"d.
標eighs 18 lbs.
measures 32 x 14 x 8"d.
weighs 18 lbs.
:)Good ideal!;)BUT a 20# propane tank when full weighs 38 to 40# and will run 12 hrs(your figure) so if it takes 6 hours to heat 1200 gallons of water then that's 2 uses per bottle and it will take the best of one day for one mule to pack 3 tanks in to camp for 6 days use and another 1/4 of a mule to pack in the others mules feed!??? In camp I have a unlimited supply of fire wood. I need to stick to useing fire wood as my heat sorce, free and don't have to pack it in. use my mule to pack something else in.:drink:
2020 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2014 VOLVO A40G WATER TRUCK (A60429)
2014 VOLVO A40G...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A60429)
2019 KUBOTA KX71-3...
