check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,174
- Tractor
- 2009 Kubota BX25
Generac's are vulnerable to Gasahol, carbs will corrode. I solved the problem by using Staybil 360 Marine additive. Mine (17.5 KW) has worked fine for 18 months now after making the fuel change. It has no adverse effect on our motors and electronic gear. Their guarantee states that the warranty is void if Gasahol is used. Their manual states you have to drain all fuel after each use. Holds 15 GL in the tank so you figure. I now never drain the fuel. Ron Ron
What??!! Drain all fuel after each use? Do all the Generac generators require that?
