Pole Barn heating-what do you use?
/ Pole Barn heating-what do you use? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
I just wanted to start a thread on heating a pole barn. Say it's a typical 60x40 metal sided with concrete floor. Let's say the roof & walls have Tuff-R on them and the floor has 2" under the slab.
I'm thinking of radiant heat-running tubing through the slab to the south facing roof to be preheated in solar panels. The water temp could then be supplemented higher through a simple boiler/water heater with a circulating pump. Maybe use waste oil to fire the heater or electric.
I like the idea of using solar to preheat the water as much as possible (free). A simple shut-off valve could prevent heat in summer.
/ Pole Barn heating-what do you use? #2
on most solar systems you can't just shut valves the collectors will over heat and if its sealed and blow releif valve if there is one if not some thing else will have to give.
tom
Thanks. Yes, I planned on draining the sytem in the summer. Since it'll be filled with anti freeze & water, it's not something you'll want blowing out on the ground.
/ Pole Barn heating-what do you use? #4
We usually cover the collectors in the summer. Too much risk of overheating damage to internal components, even if left dry.
/ Pole Barn heating-what do you use? #7
We cover them with plywood painted white, spaced up by strapping around the edges to keep it off the glass. My father in law puts foam in between plywood & glass. I never have.
I woder if you evacuated the system of most all of the fluid and opened the relief valve, if that wouldn't suffice? Just so you wouldn't have to climb up and cover/uncover the panels?
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
2022 MAXEY MAXX-D 40’ GOOSENECK EQUIPMENT TRAILER (A59914)
2022 MAXEY MAXX-D...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
Cultivator (A62613)
Cultivator (A62613)
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
