Pole Barn cost questions
/ Pole Barn cost questions #21
I should also add that I am using rafters at 16" OC, not trusses at 4' OC, as is typical around here for a pole barn with a metal roof. The second story loft is 2x6 stick built framing, and the poles are 6x6 PT. It is overbuilt, but still affordable and quite large. I have the poles, headers, second story joists and flooring up already. I have been meaning to get some pix out here, but don't have the time to stop and snap. I have to use every available moment building, so that it gets done sometime this decade /forums/images/graemlins/confused.gif
Larry... I have not contacted Miricle Truss yet to ask this question, but I was wondering about roof pitches. Do they offer different pitches? One of the designes we are considering has a 10/12 pitch. The design is an East Coast Salt-Box style barn. I know I can have it built by any of the pole barn companies, but as I wrote earlier, I like the steel frame and clear span of Miricle Truss.
Paul ... the Monitor style barn is on the wife's list of possible choices. It would be nice if you could keep us all informed of your progress and post photos as you move the project along.
/ Pole Barn cost questions #24
The plans for my pole barn are very similar to yours. My main span is 20'x30'. I've got a 14" I beam that is 20' that will go across the front of my 20'. I've collected over the last 2 years the used utility poles needed. My plan is to have the height of the first floor at 11' and a 6' knee wall with a 6/12 pitch using home built metal roof trusses.
I've built my own band saw sawmill to mill up the 2"x's and 10"x oak beams. saw
link to saw
My job is going away at the end of the year and the prospects are slim to nil right now, so I may be getting a good start on it shortly. I've actually been grading the pad for it over the last 2 years whenever I have a free hour or two and the ground isn't a muddy mess. I've cut a good 24" off the top side so far and have it pretty level. Final grade will be roughly 12-14" above the present grade. I've going to install plenty of drain tile and a lot of gravel.
I'm not suppose to install a metal roof according to our covenants, but with it being on the backside of the development.... /forums/images/graemlins/smirk.gif
gary
gmason. . . watch those covenants! 2, 5 or even 10 years from now one of your neighbors, or even a new person into the area can get in a beef with you and toss a suit at you forcing you to rip off the roof. It happened in my neighborhood. We have 26 or 27 homes in a 155 acre neighborhood, 6 miles from the nearest town and totally surrounded by agricultural land, and some people have found out the hard way that they should not flaunt the covenants. We do not have a rigid board of directors or anything formal like that. But some people specifically buy into an area with covenants for the protection they offer in terms of property value protection.
If I was you I would built to the covenants specifications.
I make sure I follow the covenants more than the county building codes!!! Half of what I have never got the required permits, but I met the covenants that went with the property title!!!
/ Pole Barn cost questions #26
Bah! I'm glad our new property has no covenants! Sounds as bad as homeowners associations!
Ken
Slow... covenants and associatons have good points and bad points, and it just depends on what is good for you. In my area they are havens for nicer houses and nicer barns and higher property values. But some people buy in a rural area thinking they can park their cars on the lawn, put up workshops that discharge sawdust onto their neighbors yard, etc. Those people end up getting smacked, and usually move out pretty quickly. I lived for too long in an area where anyone can do anything, and FOR ME having the covenants is a great thing because it prevents an idiot neighbor from destroying the value of my property by turning his property into a blighted eyesore.
In my case, I have 2 lots side by side with 650+ feet of frontage and my house is one of the big houses in the area, so I have more to lose than someone else. And I got myself onto the architectural control board, which is a permanent position until I resign, so I get to be a dick sometimes but it helps the overall group.
IT IS NOT FOR EVERYONE but having covenants and associations can be good if you are looking for protection FROM your neighbors.
Most of the people who live in the area are great people who do everything they can to upgrade their property. But a few people have tried to get around covenants and rules and they end up pissed off because they can't build an eyesore on their flat treeless 2 acre lot. They are usually the same people who drive snowmobiles & 4 wheelers through the front and back yards of all their neighbors, and their kids are the ones who play music in their cars so loudly that it shakes you in your house when your windows are closed eventhough your house is so far back off the road that you can't even see the car driving by. And those are the people who I want protection from and that is why I am glad (MORE ME) that I moved into a neighborhood with covenants. But I certainly understand why others choose to avoid land that has covenants and/or associations.
/ Pole Barn cost questions #28
around here, we don't need covenents..... if you can afford the land, you definitely won't build a slum....
/ Pole Barn cost questions #29
Which way does it face? Are any of the elevations facing north? I ask because I think that gives the best light.
You can always go to the board for a variance. Some metal rooves can't be told from shingles. They are expensive though.
/ Pole Barn cost questions #30
Stan,
I assume your question about North is regarding my elevation drawings. The side elevation is the south side. It faces nearly due south, maybe a few degrees to the east.
I have started a new thread with photos of my barn in progress for those interested under this link .
/ Pole Barn cost questions #31
Bob,
I am reasonably confident that they can do a 10/12 pitch. I have been dealing with Harold there and he is very nice to deal with. My building arrives this week!
Larry
2007 Roadmaster Camelot Monaco Motor Home (A62613)
2007 Roadmaster...
Stout Buckets HD72-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
2009 IC Corporation School Bus, VIN # 4DRBUAAN39B694287 (A65563)
2009 IC...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
