Polaris 700
/ Polaris 700 #1
ortiesdad
20 miles east of Pittsburgh
Kubota L3800 and International 460 Utility
I have a 2003 Polaris Sportsman 700 that only has 84 miles on it. I've used it only for working...skidding logs, hauling a trialer full of wood, plowing snow....It now runs like 'crap'! It has no power at all and the flashing light on the speedometer tells me that it's over heating within a few minutes of startup. Any suggestions??
Thanks!
Dave
/ Polaris 700 #2
ortiesdad,waterpump? doing its thing ,radiator damage?air filter clogged? this is injected right? injection is pretty finicky about air filter and there may be a sensor in the exhaust pipe that may have come unplugged? HMMMM?? /forums/images/graemlins/crazy.gif
could be lots of things IMO
/ Polaris 700 #4
Dave, My 2002 700 overheated last fall. Fortunately, I was only a couple of miles from home so I could wait till it cooled down, drive 3/4 of mile, let it cool again until I made it home.
It turns out the cause of the overheating was the nut holding the water pump impellar had loosened. My Polaris dealer did the repair without charge even though my original warranty had expired.
I was advised that many of the 700s had the same problem. Of course I asked why Polaris had not recalled the ATV if there was a problem. He had no answer only to tell me that it was a "fix as fail" repair.
I suppose I should be thankful that it was repaired without cost. But it irritates me that Polaris knew they had a problem but forced me to wait intil the ATV failed. Not a real big problem when I'm only a couple of miles from home. But if I had been trail riding in Northern Minnesota where the repair shops and trail stops are few and far between a failed water pump could be more than just an inconvenience.
Whether the 2003 700 had the same problem I don't know but it might be worth checking.
Terry,
500 BBL FRAC TANK (A68842)
500 BBL FRAC TANK...
2006 KENWORTH W900 (INOPERABLE) (A67714)
2006 KENWORTH W900...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
THREE METAL FRAMES (A68842)
THREE METAL FRAMES...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2018 Dodge Charger Sedan (A66738)
2018 Dodge Charger...
