Poison Ivy
/ Poison Ivy #41
So I just cleared my patch out. Spayed the area with very soapy water twice, in hopes of removing as much oil as possible. Heavy rubber gloves to pull the plants up by the roots. Pulled everything up so that it had no where to hide. Washed gloves, boots, arms with dish soap. Clothes turned inside out when removed to prevent any oil transfer and placed in the wash. Showered with dish soap. Washed boots again. Sprayed area down with soapy water again. I'll have to keep an eye on the area. I'm sure some will be back.
Wish me luck.
/ Poison Ivy #42
<shift
Strip clothes right into the wash... except underwear.
Take a cool shower with underwear on and use Zanfel liberally....
TMI, we don't need to read about your underwear :)
Wish me luck.
Why did you even bother touching it at this time of year? A good heavy dose or two of a woody brush killer would kill it and then you could pull it in the fall/winter.
/ Poison Ivy #43
Wish me luck.
get back with us in 3 days
/ Poison Ivy #44
I've only had 3 or 4 small spots that I suspected were caused by poison oak/ivy in my 65 years. They itched like crazy. Those who are severely alergic have my symparhy..
/ Poison Ivy #45
Speaking of Poison Ivy, does anyone else remember this song.
We have Poison Oak out here on the left coast. I've had pretty bad cases of both.
/ Poison Ivy #46
QUOTE My BIG problem the first time I got it was that I scratched my privates before I knew I had it. Sometimes swelling is NOT good.
\LOL, I once had to crawl out of a ditch ditch (don't ask) and unknown to me there was poison ivy there.
Since I was wearing shorts the blisters spread all the way to my 'private area'.
I can totally sympathize with you!
/ Poison Ivy #47
I still remember Senior year (1969) in high school in Vermont. There were VERY few places with active poison oak or poison ivy, it was essentially the end of it's range back then. I'm surprised you have it in Canada.
One known place was an island in Lake Champlain with a reputation as a "passion pit". Just before summer break it happened that 2 well known, popular girls got poison ivy ALL over. BUT the two guys which they were supposedly "steady" with at the school did not. However it was rumored that there were two freshman college boys breaking out all over. Probably just coincidence.
/ Poison Ivy #48
My wife is highly allergic to PI. She will get swollen areas covered with layer upon layer of blistered and using sores, several inches across, turning the skin dark purple all around it. It can take weeks for the oozing to stop sometimes. It goes so deep into the skin it causes scars that last for over a year. Because of this, and because she loves to work outside and to landscape, we're always on the lookout for PI. PhysAssist covered the treatments well. We use Tecnu religiously, and found it works very well if you follow the directions, and then some. You need to rub it on/in your skin, and continue to massage the affected area for several minutes. And I mean by the clock, at least 3 minutes. Add some more if it starts to dry out as you rub it. The best way I can describe it's action is to think of it removing the oils just like Goop or DL cleaners remove dry paint on your skin. You have to give it several minutes to break down the paint/oil, and then all of a sudden it dissolves it quickly. I apply the Tecnu even to areas that have already blistered, and it really slows the reaction and speeds healing.
As others have said, I chop the vines with loppers or a machete, and paint the stump. I use Crossbow (or generic Cross Roads) painted full strength on stumps, and also spray lanes with that using 2 oz per gallon of water to kill PI quickly without harming grasses.
This!
Try Zanfel and Zyrtec though, they work way better once a rash has already begun!
/ Poison Ivy #49
It's everywhere in Quebec. I have pictures of roadside ditches that are carpeted with the stuff.
/ Poison Ivy #50
With Warming it is spreading North...
Here Poison Oak is the bane and it pretty much stops with elevation and snow line...
I've been fighting it for decades on 20 acres of ridges and valleys... got a good handle on it now but still do several Springtime search and destroy missions with my backpack sprayer...
/ Poison Ivy #51
A couple of years? Wow. Guess I may suit up. Try to pull down and spray bottom. Need it off of at least the one tree. The others I can deal with slow.
Depending on your climate in the summer you may not have to wait too many years for the upper part of the vine to wither enough to fall out of the tree. If it's attached to the tree you'll have a difficult time pulling an essentially live vine out of the tree. How big is the base of the vine? Is it attached to the tree?
I've used 2,4 D for poison ivy/oak when painting it directly onto the cut stump end of the vine. In Texas you can buy up to a quart of 2,4D without a private applicators permit.
When you pull down about 20-30 feet of fresh cut poison ivy vine out of the tree, what are you going to do with it?
TBS
/ Poison Ivy #52
For the stuff climbing trees, cut a section of the vine and paint the ends with Tordon - same thing as I use when I cut tress I do not want to grow back.
I do not tend to argue with the stuff in the summer - there is just too much liquid flowing in the plant and I am allergic. I mark it, wait until it goes dormant and then cut it. If you want to pull it down and pile it it will burn safely IF you let it it get good and dry so the fire is very hot. Too many people want to get rid of it now and try to burn it in a smokey fire - not a good plan.
Yes the resin sticks around for a while - the larger the stem the longer it stays.
I have found sprays will kill it but not with just one application unless it is a glycosphate (Roundup) and you get it covered. What I have found is that it needs partial shade - if you can get sunlight to it it will die off.
Poison Oak on the other hand doesn't seem to mind the sun and is a much bigger problem for me. I usually get nasty with it in the winter time - when I can comfortably wear lots of protection, the oils are not flowing, and there are a lot less leaves to potentially touch.
/ Poison Ivy #53
I was cutting some poison oak vines this afternoon that wrapped up Oak trees.
The biggest was about 2" diameter at the base... all I did was snip... it is growing between the creek and my ranch shop building and was over the back edge of the roof...
/ Poison Ivy #54
On the aftermath part. I learned this from a doctor after I got a good dose one year.
First shower should be as cold as you can stand it in order to close the pores.
Then after washing off the oils with whatever soap(dishwashing here), crank the hot up as much as can stand. This temporarily deadens the nerve endings lessening the itch. Let you get a night of sleep!
I do what I need to with the vines. Then paint the cut end with roundup pro. Never do burn it due to smoke scare mentioned earlier.
/ Poison Ivy
Think I may have a lead on someone that is immune. Hopefully I will find out for sure and can get it taken care of. At least on the one tree by the playhouse. Once it's out I guess it will have to be bagged by them and hauled off.
/ Poison Ivy #58
Lots of great advice on what to do after encountering it. When all that fails and I start to itch, I've found the Gold Bond Rapid Relief anti itch cream works the best for me. I've also learned that what works for one person doesn't always work for somebody else, so figure out what works the best for you.
If you have poison oak in one area, you have it everywhere. For the areas that I enjoy the outdoors, and hang out in, I've found that the best way to kill it off is to expose it to direct sunlight. It loves the shade, hates the sun. Prune the trees, take out some saplings and bushes, and you'll be surprised how quickly it dies off. To get rid of it, I just mow it. Mow it over and over again, and in a few months, grass will fill in, or some other brush will take over.
I have never in my life tried to remove poison ivy from a tree, or get it out of the ground. My wife will spray it with poison ivy killer spray and feels that works for her in shady areas, but I'm so afraid of snakes that I rarely go into those areas, so I don't mess with the poison ivy there.
If you do pull it, don't be afraid to burn it. I would stand in the smoke or breath in heavily if you find the smoke is all over you, but with a little common sense, it should be an issue. I burn trees all the time that I've taken out in areas that I'm clearing that have poison ivy on them without concern for the smoke.
/ Poison Ivy
Found my solution. Having some ground work done and one of the guys on the crew was immune to it. I can't believe how good of a job he did trees are clean as can be. Now I just have to monitor and kill anything that pops up. Thanks for all of the pointers.
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2020 INTERNATIONAL...
1999 TRAIL KING T/A DETACH (A67714)
1999 TRAIL KING...
2011 Chevrolet Express 2500 Cargo Van (A66736)
2011 Chevrolet...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
PALLET OF HEAVYEQUIPMENT PUMP PARTS (A68842)
PALLET OF...
