Plugged up pond overflow pipe
/ Plugged up pond overflow pipe #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
The pond on our 20 acre site has an overflow pipe that (apparently) the beavers plugged up before moving on a year or so back. The level is now about a foot or so too high & ground on the upper side of the pond, which normally would drain into the pond, is getting pretty swampy with the recent rains.
The overflow pipe is 6" PVC in an L configuration, with the inlet being vertical & the outflow behind the dam roughly 8 feet (or so) below the inlet & about 40 feet back. Getting to the inlet is pretty much out of the question for me, considering the distance from the bank, pond edge growth, water depth & bottom conditions ( & my mobility issues). The outlet is reasonably accessible, though not really great footing for me.
I'm trying to figure a workable plan for unplugging the pipe. I'm thinking that if the blockage is from the beavers shoving stuff down the pipe (plus pond weed ,etc.), I might be able to apply pressure from the outlet side & blow it out.
Lowes sells a device for clearing drains that is inserted into a drain, inflates with water pressure to seal the pipe & then lets water pressure build up beyond the device til the blockage is shoved through. I've got a 120v pump from a former goldfish pond that pulls about 150 watts & can generate about 60 lb. of pressure (as memory serves). It has fittings that match water hose connections. I was thinking about running it from a 450 watt 12v inverter, pulling water from the pond to feed it.
Another approach might be to solvent weld on a threaded end & use a screw in plug with a schrader valve installed in it to try air pressure.
Any other suggestions/observations are definitely welcome, as are alternatives if this initial approach doesn't work.
Nick
/ Plugged up pond overflow pipe #2
did you try a simple snake just to see if that'd losen it up enough?
/ Plugged up pond overflow pipe #3
I made a plug out of a pipe cap for PVC pipe and drilled and tapped for an air chuck and took a air tank and shot blasts of air into the pipe to break it free. If that doesn't work I would fill the pipe with water and then hit it with air. :thumbsup:
I didn't have one heavy & long enough to try it working from the outlet end (& wasn't confident enough of the outcome to buy one to try). Do you think a 50 foot 1/2" flat rod snake would be sturdy enough to be worthwhile?
Nick
/ Plugged up pond overflow pipe #5
Nick
It might be worth a try, if not can you rent one from lowes or ????. I was just trying to think of the easier solution 1st.
I thought I'd post an update. Since the first post, I've been back up to our old place in WV & brought back an air compressor from my shop. Yesterday I glued up a 4" threaded fitting to the overflow outlet and installed an air chuck on the corresponding threaded plug.
It was really past time to get this done, the pond was actually high enough to start seeping over the "lower" end of the dam and the field above the pond was showing standing water in low spots at roughly the level of the pond surface - pretty much becoming swamp.
So this morning, we put the compressor, a generator and 100' of air line in the truck & took it over. It took no time for the air pressure to work out the blockage.
After about 6 hours of outflow, you could finally start to see a "hole" in the water above the overflow inlet.
The wife feeding out the air line
The plug installed on the outlet with airline attached
Air churning up through the overflow inlet
also
Excess water finally draining off the pond
A youtube recapitulation w/ short video clips
Nick
/ Plugged up pond overflow pipe #8
there is a power washer attachment that will blast out the clog but not the pipe teh water behind cleans the hole its what the city sewr trucks use here
/ Plugged up pond overflow pipe #9
Good job. Congrats.
Don't you love it when a plan actually works just as you envisioned it??? It gives you a warm fuzzy feeling doesn't it?
Did you warn the people downstream of the impending flood? :)
/ Plugged up pond overflow pipe #10
Now the beavers have a challenge!! They'll probably bring in a cement truck and re-bar for the next "plug":laughing:
They where probably "making calls" before you got out of the driveway:D industrious suckers
/ Plugged up pond overflow pipe #11
Good job on getting the water to flow.
The beaver will likely try again, and maybe a stand pipe that is perforated with drilled holes could be added to the inlet (act like a cage). but less debris could enter.
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
24in John Deere Rims (A63116)
24in John Deere...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
