Plug wielding---- when is it needed?
/ Plug wielding---- when is it needed? #21
Anything added will help. This is either a design flaw, or abuse. He said it wasn't abuse, so we have to take his word for it. I'm not an engineer, mis spell it most of the time!:eek: All I can help with is what I've done in the past.;)
/ Plug wielding---- when is it needed? #22
Is there any adjustment to the spreader axles? The failure looks like it was aggravated by tongue weight or braking under load. If you could move the axles forward, you could take some weight off the tongue. Fish plating will get you back in business, but it shouldn't have failed in the first place. Make sure your dealer sees the picture you posted. I'd be steamed. Those spreaders aren't cheap.
/ Plug wielding---- when is it needed? #23
A lot of tongue weight on that spreader, maybe take off the suitcase weights
/ Plug wielding---- when is it needed? #24
I was thinking China Steel.
Added weight merely neutralizes the injector system that is attached to the rear of the applicator, and creates a upward force on the tongue.
Thanks for all the comments.
Reason the box tube broke......... there are torsion bars under the applicator, and are hooked to brackets just behind the break. Those bars create tremendous downward force, pulling on the box tube. Unit broke the box tube for previous owner, but previous owner fixed the break by merely welding the break.....no fishplate. That break was not noticeable due to a good job of painting and grinding, until it broke the second time, which exposed the weld inside the box tube.
We fixed it by fishplating on the sides, since brackets were in the way top and bottom.
We will see how it handles.........but at least now there is a lot of metal ahead of the torsion bars.
Again, thanks.
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
