Plowing stony field
/ Plowing stony field #1
L3650
I have been asked to plow about 15 acres of fallow field. It has not been plowed for at least 30 years. The part of eastern Wisconsin this land is located has a lot of glacial debris. Endless stones range in size from golf ball potato to basketball to the size of a car. And there are alot of them.
The gentleman living on this farm today has an old pull type 2 bottom Oliver plow and a Farmall M tractor. He states that it was the set up used to operate the place for years, but the tractor is too tired to pull the plow. I know the Kubota L3650 will pull that plow with ease.
My question is what if I hit a large rock? I have never plowed a furrow in my life.
Do I use the old Oliver plow? It has a trip mechanism to release the plow should it become hung up. I had been thinking of buying a 3pt, 2 bottom that would be used to put in food plots. None of the new 3pt setups appear to have trip mechanisms.
I would like to plow the field, but I don't want to harm the old plow or my tractor. Any thoughts on how to approach this is appreciated.
/ Plowing stony field #2
Part of my hay field is very rocky like you describe. I have not plowed it yet with the new tractor but in the past using the Jubilee and a 2 bottom 3 pt. plow it would mostly jerk to the side or come up out of the ground, occasionally it would grind to a halt and start to spin. I keep my foot lightly resting on the clutch pedal so I can get stopped quicker. The lift arms on the jubilee have a lot of play in them and I think this allows the plow to go around some rocks (don't help much for straight furrows). The new JD has very little, if any, play in the arms and might make for a very rough ride. Just hold on and stay alert. The plow with the trip mechanism sounds like the way to go.
/ Plowing stony field #3
Our old place had ground like that and its sure hard on equipement. We used a Farmall H with a similar pull type 2 bottom plow that also had a release mechanisim. There is no way I'd use a nice tractor with a 3 pt plow for that rocky ground. Some rocks were so big we couldn't move em with the stone boat.
/ Plowing stony field #4
Tighten your seat belt it's a rough ride! Rocks, roots, & 30 years of everything else. You need 3-5 mph to make a furrow flip, otherwise it just falls back /forums/images/graemlins/shocked.gif
I use a modern spring loaded 4x18 with on land hitch so all the shock loads are on the drawbar and wide spacing to clear the trash. /forums/images/graemlins/grin.gif
Old plows will simply load with trash & pop out of the ground.
If the grass is more than knee high mow it first to help see obstructions & holes.
15 acres of rock picking will take awhile /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
/ Plowing stony field #5
Use the old plow. Make sure the trip mechanizim is working.
A farmall M could pull lots more than two bottoms.
Egon /forums/images/graemlins/grin.gif
/ Plowing stony field #6
Have you thought about declining the job? It sounds like one of those jobs that will be hard on your equipment, take way too long to finish, and still not end up with good results.
gabby
/ Plowing stony field #7
We use to have what is known as disk-breakers. Big disk blades about 2 foot high spaced maybe 14 inches apart. they work great on groun that had just been cleared, you now that have some stumps hidden in places. They are just to be pulled and not picked up. That would be something to lood at if available...........luck to you teddydo
/ Plowing stony field #8
Use the old plow or as suggested, get a disc plow. I just purchased a two bottom Dearborn Disc Plow. It worked well on the stumps and brush I had to remove. The suggestion of walking away is not too bad. This could be a chore.
/ Plowing stony field #9
If the land had been plowed/tilled even 30 years ago, most of the "big" rocks will have been removed already. If the plow was the original used on that field, look at it. It will tell you the conditons. I will assume its probably a "Little Genius" IH plow. Suggest you get a picture here of the plow, particularlly the points/shears, shins, etc. Does it have colters?. As mentioned earlier, cut over the field with a brush hog: twice--once at about 6 inches to save the hog and then again somewhat closer. to beat the stubble up and get a real look. Oh, even a "tired" M will still have as much HP as your Kubota. They were rated between 40-couple and 50 HP. It will pull the plows easily. Check the tires for dryrod and if the wheels have weights--as that will tell you if its gonna pull thru the "stuff" you will encounter. Good luck. Sound like a Neat project to me. BobG in VA
/ Plowing stony field #10
I grew up in WI and have experience plowing these kinds of fields. I would use the old oliver plow (we have an old 3x16). If you hit a stone that is too big, the moldboard will trip over backwards, just backup and lift over the rock. I would definately use the kubota. An M should pull 3 x16s, but traction is more of a problem and fuel use on the M will be 6-8 Gallons per hour for plowing. You could get a newer type with spring resets, which will will only speed you up a little. Your choice, but I would use the old plow. You will need one pair hydralic remotes and a ram.
Good luck
Mike
/ Plowing stony field #11
Got to agree. The old trailer plows are the easiest things to set up and use. I have never seen any that wouldn't plow. If the points are any good at all, they will turn a good furrow. The three point plows, on the other hand, take some TLC to make work. Personally, I would pull them one gear slower rather than faster, as they weren't designed for high speed like the newer plows. One other note about that old "M". When those plows suck in about a foot and the "Bota" is having second thoughts, take a look at the "M' and know that it pulled those guys any where any time.
Well, I plowed the field with the Oliver 2 bottom 14 inch pull behind plow. Everything was already set up and it worked great. Only tripped four times on a couple of bushel basket size rocks that I dug up with the FEL.
The whole operation took a full day. The Kubota dug in and was working, but it was not a strain.
I was mistaken about the old tractor on the place, it is a Farmall H, not an M.
It was fun, and I used about ten gallons of fuel.
I think the L3650 has 38 hp, 34 pto hp. It has a Glide Shift transmission. The ag tires are filled and with the FEL it weighs in around 5300 pounds. I don't drive it across the lawn very often.
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
