Plowing Experience
/ Plowing Experience #11
Steve and Bird are way over my head here, but, wouldn't draft control help is this situation?
Billboe
/ Plowing Experience #12
Billboe, you'd still want to have the plow adjusted or set up properly, but yes, if your tractor had draft control, it would adjust the depth if the plow were pulling too hard or too easily.
/ Plowing Experience #13
Most 1 or 2 bottom plows we used had a depth adjustment wheel. Thats what was on my 2-16 massey plow that I let go with my old tractor. I also had to adjust the tire inwards in the furrow for proper distance for the plow. But growing up I plowed with a 4 bottom or 4-16 hydraulic john deere plow behind a 70 john deere. Lots of fun there/w3tcompact/icons/smile.gif
________________________________________________
Take care all, Jim
2001 B7500 HST 302 Fel R4 Tires, Befco BRB60
Semper Fidelis<P ID="edit"><FONT SIZE=-1>Edited by Devildog on 11/06/01 12:35 PM (server time).</FONT></P>
/ Plowing Experience #14
Re: Plowing Experience-14- 14\" Bottom Plows
14 Bottom Plow with 45 HP Steam engine...
"You are what you eat, drink, think, say and do..."
/ Plowing Experience #15
Re: Plowing Experience-14- 14" Bottom Plows
14 Bottom Plow Front View...
Eric...with some practice...see what you can do? /w3tcompact/icons/tongue.gif
/ Plowing Experience #16
Re: Plowing Experience-12 Bottom Plows w/35 HP eng
12 Bottom Plow with 35 HP Steam Engine @ 260 rpm
About 1908, see how hard work was done...
/ Plowing Experience #17
Thanks for the pics John. Now that is what I call some serious plowing. I like the fact that the steamer is only turning 260 RPM's
___________________________________________________
Take care, Jim
Semper Fidelis
/ Plowing Experience #18
Wow, in the field (no trees), ground engagement equipment and ROPS folded.
You are much braver than I am.
/ Plowing Experience #19
John,
Thank you for the pictures. Very interesting stuff!
A 12 and 14 bottom plow with only 35 or 45 horsepower! /w3tcompact/icons/blush.gif/w3tcompact/icons/shocked.gif/w3tcompact/icons/smile.gif That means those old steam tractors had tons of torque.
I have 20hp and can only use a single bottom plow. Go figure?
Terry
/ Plowing Experience #20
I think they used a different way of rating horsepower up until the early 1900s. SAE horsepower instead of brake horsepower maybe? I know that the largest Case steam engine of the time was originally rated as 32 horsepower with the old system. When they changed ratings the same engine was now rated at 110 hp. From this it is probably safe to multiply those numbers by about 3.5 in order to compare with todays horsepower ratings. Also, with those old steam engines weight and torque where larger factors in how much they could pull instead of horsepower.
72% of all statistics are made up./w3tcompact/icons/smile.gif
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
ATTENTION PLEASE READ (A60462)
ATTENTION PLEASE...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
