rototillers vs plow & disc
/ rototillers vs plow & disc #1
fatjay
Elite Member
Eastern PA
Not enough
I move slower with rototillers, but move faster with a plow & disc. But I make multiple passes with plow & disc. Right now my rototiller tractor is a dedicated machine, I was thinking of getting a 3pt rototiller. I do about 1 acre in one field and 2 ½acre fields. I can run plow and disc with 3 different machines. What is the fuel compared between the two? I feel like hte rototiller has better soil mix, but how big of a difference is that in yield? I do corn in 1 acre, and the others are just various. Not large scale stuff.
Is the improvement in soil mix/quality much for rototiller, vs the plow and disc to justify the increased fuel?
/ rototillers vs plow & disc #2
running a tiller (at pto speed) is not harder on fuel than running a bush hog. Buying a good tiller is scarier than the fuel to run it.
/ rototillers vs plow & disc #3
I have clay loam, so I really appreciate the one pass to create a good seed bed. The tiller makes a very fine and uniform bed to plant seed in.
I travel slower, but fewer passes, maybe 1.5 gallons per acre.
  • Good Post
Reactions: JJT
/ rototillers vs plow & disc #4
Those are 3 different implements for 3 completely different purposes. I run all 3 every year. I don't run a turn plow but have replaced that with a chisel plow.
/ rototillers vs plow & disc #5
What type of soil conditions are you working in? If plow is working correctly one pass with disc should level the field for planting unless breaking up sod. To work correctly a mold board plow and disc should be pulled around 4 - 5 MPH.
/ rototillers vs plow & disc #6
I have all of the above;tiller after plowing works the best for me;also levels the ground.we do about 10 acres a year(21 years).We also cultipack after planting.
This is all red clay. My tilling tractor is a 14hp new holland s14 gas. I till at about 0.5mph, and occasionally slower. I pull a 14-2 bottom plow with either my kubota or ferguson. If I got a 3pt tiller I'd put it on the kubota which is diesel and gets better fuel economy than the gas. Also I'd be hoping I could move faster than the new holland.
From year to year, the soil manages to completely compact. I was thinking a tiller may be easier. The big field is corn and after I collect, hand picking, I leave the stalks and just turn over everything in the spring and then disc it.
/ rototillers vs plow & disc #8
In my opinion, a plow/tiller combination is best for garden plots used repeatedly. A tiller provides the best fluffy soil seed bed, but overtime a hard pan will develop in the soil just below the tilling depth. I have a Fred Cain ripper plow that I use in the fall and spring to loosen the soil deeply, then follow up with the tiller before planting.
/ rototillers vs plow & disc #9
I was in the same boat with clay and compaction until I added an enormous amount of compost and lime. I've added so much compost to my garden that it's now a raised bed and the soil is like potting soil, (black, crumbly and well drained). It took years to get to this condition.
/ rototillers vs plow & disc #10
Another thing we do is bush-hog down any standing food plots before working.
/ rototillers vs plow & disc #11
Soil gets "HARD" when the organic matter is eliminated, and the soil is broken into too small of crumbles.
I feel that breaking organic matter into tiny pieces makes it decompose too fast to do the garden any good.
You need organic matter in the soil,, not simply clay.
The general consensus among some "organic" gardeners:
Tillers of any sort reduce or eliminate the tilth of the soil
TILTH
cultivation of land; tillage.
  • the condition of tilled soil, especially in respect to suitability for sowing seeds.
    "he could determine whether the soil was of the right tilth"
/ rototillers vs plow & disc #12
I try to not till or plow the garden every year, sometimes as infrequent as every 5 years.
When I do want to "plow", I use a Gravely rotary plow.
As far as weed control, I try to stick with a Gravely cultivator
(machine on the left)
It only disturbs the soil deep enough to knock down the weeds, it can not go deep in the soil.
My other option is a Troy-Bilt Horse, set to till very shallow,
again only disturbing the weeds, not the organic matter or the worms.
/ rototillers vs plow & disc #13
I till in buckwheat twice per year. Do you know how much organic matter is in an acre of buckwheat? 😂
/ rototillers vs plow & disc #14
Only use a rototiller here and the ground is very soft about
8 inches deep very easy to plant anything we want
willy
Rototiller I sometimes have to make 2-3 passes to get to full depth. It rotates forwards, so it sometimes propels me along the soil is so hard.
This isn't the field, but on the second run, you can see what happens in this video.
/ rototillers vs plow & disc #16
You've got hard ground, and it is normal to have to make multiple smaller passes to till it. It would take a lot of organic material like sawdust to loosen it up. Even if you plow it, it will still compact like hard ground until you get a lot of organic material into it.
I know this because I started a garden spot 20 years ago in hard ground. Years of organic material have improved it, but it's still not the best soil.
/ rototillers vs plow & disc #17
I have a Gravely rotary plow that still amazes me for how it fluffs the ground in one pass.
/ rototillers vs plow & disc #18
I had to make three passes on virgin clay loam to get a good seed bed. After that, one pass is enough, it's remained very soft.
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2015 Lincoln MKZ Sedan (A59231)
2015 Lincoln MKZ...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
FENCE PANELS (A58214)
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
