Plans for removable canopy comments
/ Plans for removable canopy comments #11
One of those big cowboy hats should work fine. Lots of coverage and easy on easy off.
Egon
/ Plans for removable canopy comments #12
Looks good- much more sophisticated than my plan, which uses 1/2" plywood and 1 1/2" flat stock.
You may have to make your own U-bolts- I haven't found square U-bolts in that size. Also, pop rivets may be the simplest way to attach the top.
/ Plans for removable canopy comments #13
I'm afraid I took the easy way out. When seat time comes and the sun is up and hot, it's a big white straw hat and a long-sleeved white shirt. One nice feature is the "canopy" goes up and down with my head /forums/images/graemlins/smile.gif..............chim
/ Plans for removable canopy comments #14
You can make it as heavy as you want. Install an eyebolt in the top and when you get to that tree, run the canopy under a limb that is high enough to clear, tie the canopy to the limb, lose the canopy, mow the grass under the low limbs and then hook back up to your canopy and go about your business. If you build it too light you stand the chance of vibration cracks in the structure. A little heft can can also keep it from disintegrating from a light brush up against something solid.
Whiskey,
I do plan on welding all but where it will bolt to the ROP with "U" bolts. I just plan on using mild sleet rather than aluminum since I have never welded aluminum before. /forums/images/graemlins/confused.gif
I had thought about putting a canvas top on it but thought if I used thin sheet metal it would last longer without having to mess with it. But I am still undecided at this point.
Gary_in_Indiana,
That verticle piece will be 2X2 tubing. Probably 1/8 ". With the gusset it should be pretty stout...but I will not be driving down any highways with it attached /forums/images/graemlins/blush.gif. I don't trust the design that much /forums/images/graemlins/grin.gif
Golfgar4,
I'll post all as this thing progresses. It might be a little while before I can actually start burning some stick though. You know the onld "Honey Do List"! /forums/images/graemlins/crazy.gif
StanInCalif,
I didn't even think about not being able to get "U" bolts! I have seen others who have "U" bolted things to their ROP.
Anyone out there that has done so....Is it hard finding "U" bolts that will go around your ROP? /forums/images/graemlins/confused.gif
If so I can just make my own.
/ Plans for removable canopy comments #19
Bnixon:
If your local hardware store dosn't carry them, I change out the "U" bolts on my boat axles every couple of years and my local marine dealer has bins loaded with them, so try a marine trailer company.
Whiskey
/ Plans for removable canopy comments #20
You should be able to get square U bolts in 1/2" increments up to about 6". If you don't find the exact size you need, just offset your holes a bit so the U bolt will be snug on each side. Problem solved! /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif
I've use 6" U bolts on a 3" piece that way with no problems at all. When I use two I angle them in opposite directions like / \ instead of // or \\ though I don't know that it matters.
Land Survey Kit (A60463)
Land Survey Kit...
Kubota SVL7S-3 (A60462)
Kubota SVL7S-3...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2023 Deere 317G (A60462)
2023 Deere 317G...
Sterling AT (A61307)
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
