Plans for removable canopy comments
/ Plans for removable canopy comments
OK guys need some help thinking through this.
I am trying to determine what would be the best material to make the canopy frame out of?
My original thought was some 1 1/4" square tubing but after adding up the weight for a 42" X 60" frame that adds almost 45 lbs. to the top bringing the total weight of the removable pieces to 77 lbs.! /forums/images/graemlins/blush.gif I think that is too heavy to be man handling while strateling the 3ph!
So here is the question:
With tubing strength is it stronger to go with a smaller outer dimension tubing with a thicker wall or a large dimension tubing with a thinner wall?
I will either be using 28 gauge sheet metal or canvas for the top so it would be a max weight of 16 lbs. spread over the area of the frame. That is not the problem as much as the strength needed if I decide to leave it on while driving down the road. The mounting brackets and gusseted uprights will be plenty strong. The frame is my concern.
Attached are the plans for the mounting bracket.
here are the upright plans
Here is the start of the frame but need some input.
Thanks again!
/ Plans for removable canopy comments #24
I'd suggest going with 1" square aluminum tubing but if you're determined to stick (pun intended) /forums/images/graemlins/grin.gif to mild steel I'd consider 3/4". either way I'd go with one cross brace instead of two.
/ Plans for removable canopy comments #25
bnixon,
Trees are a problem to mow around here, too. I mounted my Bucktop canopy on a frame with sliders to help get closer to trees when mowing. Here's a pic in standard position.
OkieG
/ Plans for removable canopy comments #26
To mow around trees (I have a MidMount Mower), I just slide the canopy back. That let's me get much closer than when it's forward.
OkieG
/ Plans for removable canopy comments #27
Pretty slick /forums/images/graemlins/cool.gif - looks like a sliding sunroof!
Mark
/ Plans for removable canopy comments #28
Finally, for backhoe work, I raise the canopy on risers. Lynch pins on the risers keep the canopy from lifting off the ROPS framework. To remove the canopy, I pull the lynch pins and lift the canopy off.
From your posts I can't tell for sure if you are trying to make your canopy moveable or removeable. With your canopy hinged back, if it's still too high, sliders might let you lower it some.
OkieG
/ Plans for removable canopy comments #29
Were these sliders and risers a part of your Buck Top package or something you customized later? Could you show some pictures of those features? How much was your canopy? Thanks.
Hey OkieG,
That is pretty slick!
Unfortunately that still will not work for my tree. Here is a pic of the tree.
I have to even fold the ROP down to keep from taking limbs off!
Well I picked up the steel today. I decided to go with 1 1/4" 16 AWG square tubing for the frame. This will give it the strength that it needs without too much weight.
How much have you guys paid for your aftermarket canopies?
All of the materials for mine that I bought today cost $180. And that was because I had to buy 20' of 2" tubing to get the 2 1/2' that I needed........That senario held true with every piece on this project(20' of 1" round bar for the 4" needed). I see fold up ramps for my trailer in the near future! /forums/images/graemlins/grin.gif
So I have about 3 projects worth of steel now. When I really look at the cost for the steel I will use on the canopy it will be about $60. That and a couple of weekends and (If it works /forums/images/graemlins/crazy.gif) I think that is a pretty good deal!
I will keep you all posted as it progresses with lots of pics!
/ Plans for removable canopy comments #32
Hello Gary,
The slider/riser arrangement is mostly home-fabricated. The square tubing that attaches to the canopy, and the bracket that attaches to the ROPS are part of the Bucktop kit. The rest is scrapyard junk. Here is a shot from under the canopy.
OkieG
/ Plans for removable canopy comments #33
Here is a close-up underneath.
OkieG
/ Plans for removable canopy comments #34
This is a shot of the riser pins that act as stops when the canopy is raised.
OkieG
/ Plans for removable canopy comments #35
This picture is of the risers extended.
OkieG
/ Plans for removable canopy comments #36
Here are the lynch pins acting as stops with the risers raised.
OkieG
/ Plans for removable canopy comments #37
With the riser lynch pins removed, the canopy lifts out of the riser guides. Here is the canopy, top down, on the ground, after removal. All that's left on the tractor are the brackets, U-bolted to the ROPS.
OkieG
/ Plans for removable canopy comments #38
By the way, Gary, these pictures are from an obscure thread I posted about a year ago: Bucktop canopy with sliders and risers. Catchy title, heh? /forums/images/graemlins/grin.gif
I can't remember how much I paid for the canopy. It was purchased at my JD dealer for retail...maybe $250-$300+??? That sounds high, but I think it was around there.
OkieG
/ Plans for removable canopy comments #39
bnixon,
Beautiful tree!!
OkieG
/ Plans for removable canopy comments #40
Yes, a gorgeous tree! I want one!! All I have are a few funky tallow trees and a half dead hackberry tree on my lot. /forums/images/graemlins/crazy.gif
I can see why you don't want to trim it back.
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
2022 EZ-GO ELITE...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
International 806 Wheatland Tractor (A66285)
International 806...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
