Ryan,
Why dick around with a pole building? Just do it right and stick build it. When you start with a pole building you fight it forever, there a bugger to insulate, you don't have to studs to hang anything on, you have to hit a perlin running side ways. I built my building in phases over 6 years. Started with a 28' X 36' 12" grade beam slab, three rows of concrete block, anchor bolts with coupling nuts and ready rod lined up so top plate is anchored to slab. 14' side wall with 12' X 12' door, 3' entry door front and rear, two windows in back one in front, 6" walls 1/2 OSB both sides, 12" blown in fiber glass in ceiling. 4/12 roof pitch. Heated with LanAir 140 waste oil heater. Second phase, 20' X 36' addition, same 3 rows of blocks, 10' wide X 8' tall, 3' service door one window in back same size as the shop. 16" Lam beams follow roof line, removed bottom row of screws pushed metal up and slipped addition metal under neath. Third Phase, mirror image of first. Fourth Phase; Concrete apron 64' X 8' all the way across, 24' X 20' in the middle. Fifth Phase; 12" cement board, aluminum sofit and facia, 2' overhang front and rear, 32" on sides. Sixth Phase; 12' W X 28' L X 10' tall on low side, lean to off back. Building is kept a 50 degrees f, takes 300-400 gallons of used oil, located in Northern WI
Here's a picture of the front
014.jpg Photo by Mark2X2 | Photobucket
Mark
