Backhoe Planning a Steel Pallet for my BX Backhoe
   / Planning a Steel Pallet for my BX Backhoe #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
This winter I want to build a steel pallet to park my BX25 BH. Hoping someone in TBN land has done this and can share plans or good pictures for me to follow. I have never believed in re-inventing the wheel if someone already has, probably several times already. FEL won't lift it; so will install wheels and a tow bar. Thanks in advance.
Ron
   / Planning a Steel Pallet for my BX Backhoe #2
A pallet... made out of steel?
Isn't that sacrilegious or something?
   / Planning a Steel Pallet for my BX Backhoe #4
Like the crate it was shipped to the dealer on?
   / Planning a Steel Pallet for my BX Backhoe #7
I am thinking of building a similar dolly for my Woods backhoe. Interested in seeing what others have done.
   / Planning a Steel Pallet for my BX Backhoe #8
I have picked up two galvanized steel pallets at the scrapyard. One corrugated solid top/bottom (heavy $30). Another slated, much lighter. Was going to use them to move 55 gallon barrels of fuel.
Made a special wood pallet/platform for my B26 backhoe from timbers to get the right height for storage on the ground. Makes reconnecting so much easier.
   / Planning a Steel Pallet for my BX Backhoe #9
I will try and take a picture of a large pallet I made for my ditch mower. Basically a tubing frame, expanded steel mesh and heavy castors. It has fork pockets but also a hinged handle for manually pushing or pulling it around.
The handle can be attached at either end. The fork provisions are garbage though. I thought this would suffice, but learned that tubes would be much, much better.
One of the things with tailored load and prep for forks; you have to be pretty close on the center of balance. You don't want a heavy side if avoidable.
Ron
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
