Backhoe Planning a Steel Pallet for my BX Backhoe
   / Planning a Steel Pallet for my BX Backhoe #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
This winter I want to build a steel pallet to park my BX25 BH. Hoping someone in TBN land has done this and can share plans or good pictures for me to follow. I have never believed in re-inventing the wheel if someone already has, probably several times already. FEL won't lift it; so will install wheels and a tow bar. Thanks in advance.
Ron
   / Planning a Steel Pallet for my BX Backhoe #2
A pallet... made out of steel?
Isn't that sacrilegious or something?
   / Planning a Steel Pallet for my BX Backhoe #4
Like the crate it was shipped to the dealer on?
   / Planning a Steel Pallet for my BX Backhoe #7
I am thinking of building a similar dolly for my Woods backhoe. Interested in seeing what others have done.
   / Planning a Steel Pallet for my BX Backhoe #8
I have picked up two galvanized steel pallets at the scrapyard. One corrugated solid top/bottom (heavy $30). Another slated, much lighter. Was going to use them to move 55 gallon barrels of fuel.
Made a special wood pallet/platform for my B26 backhoe from timbers to get the right height for storage on the ground. Makes reconnecting so much easier.
   / Planning a Steel Pallet for my BX Backhoe #9
I will try and take a picture of a large pallet I made for my ditch mower. Basically a tubing frame, expanded steel mesh and heavy castors. It has fork pockets but also a hinged handle for manually pushing or pulling it around.
The handle can be attached at either end. The fork provisions are garbage though. I thought this would suffice, but learned that tubes would be much, much better.
One of the things with tailored load and prep for forks; you have to be pretty close on the center of balance. You don't want a heavy side if avoidable.
Ron
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
NEW HOLLAND W80C WHEEL LOADER (A52707)
NEW HOLLAND W80C...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
