Backhoe Planning a Steel Pallet for my BX Backhoe
   / Planning a Steel Pallet for my BX Backhoe #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
This winter I want to build a steel pallet to park my BX25 BH. Hoping someone in TBN land has done this and can share plans or good pictures for me to follow. I have never believed in re-inventing the wheel if someone already has, probably several times already. FEL won't lift it; so will install wheels and a tow bar. Thanks in advance.
Ron
   / Planning a Steel Pallet for my BX Backhoe #2
A pallet... made out of steel?
Isn't that sacrilegious or something?
   / Planning a Steel Pallet for my BX Backhoe #4
Like the crate it was shipped to the dealer on?
   / Planning a Steel Pallet for my BX Backhoe #7
I am thinking of building a similar dolly for my Woods backhoe. Interested in seeing what others have done.
   / Planning a Steel Pallet for my BX Backhoe #8
I have picked up two galvanized steel pallets at the scrapyard. One corrugated solid top/bottom (heavy $30). Another slated, much lighter. Was going to use them to move 55 gallon barrels of fuel.
Made a special wood pallet/platform for my B26 backhoe from timbers to get the right height for storage on the ground. Makes reconnecting so much easier.
   / Planning a Steel Pallet for my BX Backhoe #9
I will try and take a picture of a large pallet I made for my ditch mower. Basically a tubing frame, expanded steel mesh and heavy castors. It has fork pockets but also a hinged handle for manually pushing or pulling it around.
The handle can be attached at either end. The fork provisions are garbage though. I thought this would suffice, but learned that tubes would be much, much better.
One of the things with tailored load and prep for forks; you have to be pretty close on the center of balance. You don't want a heavy side if avoidable.
Ron
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2007 CATERPILLAR 420E BACKHOE (A52707)
2007 CATERPILLAR...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
