PJ trailer
/ PJ trailer #1
tjkubota93
Arlington, TN
Kubota bx1860
Sold my 16ft utility trailer while it was still in good shape. Seems like I had it overloaded every time used it.
Local dealer ordered me a PJ 20ft CE. It has 5200lb axles, primer and powder coat, pinstripe delete, winch plate, and rear slide in ramps. So far I am happy with it. 20190725_171527.jpeg20190725_171547.jpeg
/ PJ trailer #2
Congrats on the new PJ. I've got 7 years on mine now. 22' full tilt 14K and still in great shape.
/ PJ trailer #3
Local dealer ordered me a PJ 20ft CE. It has 5200lb axles, primer and powder coat, pinstripe delete, winch plate, and rear slide in ramps. So far I am happy with it.View attachment 614799View attachment 614800
PJ makes a nice trailer.Had my bumper pull PJ about 8 years now.
/ PJ trailer
Cool. Yesterday I did 2 coats of linseed oil on the deck. First one was diluted with mineral spirits. Second was full strength. Mine is rated just under 10k. 9998 or something.
I was very happy to get the diamond plate dovetail. Apparently that happens on the rear slide in ramps.
/ PJ trailer #6
Curious, why dilute the first time?
/ PJ trailer
The thinking was it would soak in better.
I don't know if that is correct or not.
I read it on the internet, so it has to be true.
/ PJ trailer #9
I’ve had 3 PJ’s and still 2 of them now. All have been great. I have a 14’ utility with dual 3500lb axles plus atv side load ramps and a new 24’ F8 rated at 16k lbs. It’s a flat deck with fold over ramps. Love both of them.
/ PJ trailer #12
Do you not have a tongue jack? Or need it?
/ PJ trailer #13
I really like both your trailers.
Thanks. I’ve been extremely happy with both units. I had several guys tell me not to buy the 16k / 24’ tag along deckover as that much weight would beat me and my truck up and not tow well. However turned out to be the opposite as I was amazed at how smooth it pulls. Pulled that tractor plus the trailer coming in at just under 15k with ease from TN to NC. Also pulled a big Ford tractor through mountains of WV to Ohio smooth as silk. No need for a gooseneck as I love the easy hookup of this trailer.
/ PJ trailer #14
I have a question about the OP's trailer design that has slide in ramps and rear support jacks. If you load/unload on uneven ground, will this design adapt better than the fold up ramps?
/ PJ trailer
I'm guessing so, I wanted slide in ramps. Did not want Jack's, but they are standard.
/ PJ trailer #17
I also read that about using 50/50 boiled linseed oil and turpentine as a wood preserver when you want to paint over it. I made wooden frames for window screens on an old house I had one time and put it on the window frames before painting them. They have been in use about 30 years and still holding up well. After I sold that house the new owner called me and asked if I would make screen frames for another old house he had. I was honored to be asked but declined.
I'm glad it came up because I'm now going to consider treating the new floor I put in my 16' trailer with boiled linseed oil/turpentine.
/ PJ trailer
I used mineral spirits because I had it. Figured it would thin it out and evaporate away. Dont know if it helped or hurt.
/ PJ trailer #19
I used 1/4 diesel with 3/4 boiled linseed oil the first time I treated the wood floors on my 20' PJ. After 9 years sitting out in the weather unprotected in any manner, I went ahead and hit it again last month with a coat of straight linseed oil.
The linseed oil worked so well I also coated my new Karavan utility trailer floor last month. It too, sits outside. I can only hope that the floor in it lasts as well as the PJ. I was however, shocked at the current price of linseed oil, now about $27/gallon! What a rip. Fortunately, a half gallon covered both trailers.
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2015 JOHN DEERE 544K WHEEL LOADER (A65056)
2015 JOHN DEERE...
2015 SUNDOWNER 25 T/A ENCLOSED TRAILER (A67714)
2015 SUNDOWNER 25...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A67714)
ALLMAND ECOLED-RIG...
