PJ trailer
/ PJ trailer #1
tjkubota93
Arlington, TN
Kubota bx1860
Sold my 16ft utility trailer while it was still in good shape. Seems like I had it overloaded every time used it.
Local dealer ordered me a PJ 20ft CE. It has 5200lb axles, primer and powder coat, pinstripe delete, winch plate, and rear slide in ramps. So far I am happy with it. 20190725_171527.jpeg20190725_171547.jpeg
/ PJ trailer #2
Congrats on the new PJ. I've got 7 years on mine now. 22' full tilt 14K and still in great shape.
/ PJ trailer #3
Local dealer ordered me a PJ 20ft CE. It has 5200lb axles, primer and powder coat, pinstripe delete, winch plate, and rear slide in ramps. So far I am happy with it.View attachment 614799View attachment 614800
PJ makes a nice trailer.Had my bumper pull PJ about 8 years now.
/ PJ trailer
Cool. Yesterday I did 2 coats of linseed oil on the deck. First one was diluted with mineral spirits. Second was full strength. Mine is rated just under 10k. 9998 or something.
I was very happy to get the diamond plate dovetail. Apparently that happens on the rear slide in ramps.
/ PJ trailer #6
Curious, why dilute the first time?
/ PJ trailer
The thinking was it would soak in better.
I don't know if that is correct or not.
I read it on the internet, so it has to be true.
/ PJ trailer #9
I’ve had 3 PJ’s and still 2 of them now. All have been great. I have a 14’ utility with dual 3500lb axles plus atv side load ramps and a new 24’ F8 rated at 16k lbs. It’s a flat deck with fold over ramps. Love both of them.
/ PJ trailer #12
Do you not have a tongue jack? Or need it?
/ PJ trailer #13
I really like both your trailers.
Thanks. I’ve been extremely happy with both units. I had several guys tell me not to buy the 16k / 24’ tag along deckover as that much weight would beat me and my truck up and not tow well. However turned out to be the opposite as I was amazed at how smooth it pulls. Pulled that tractor plus the trailer coming in at just under 15k with ease from TN to NC. Also pulled a big Ford tractor through mountains of WV to Ohio smooth as silk. No need for a gooseneck as I love the easy hookup of this trailer.
/ PJ trailer #14
I have a question about the OP's trailer design that has slide in ramps and rear support jacks. If you load/unload on uneven ground, will this design adapt better than the fold up ramps?
/ PJ trailer
I'm guessing so, I wanted slide in ramps. Did not want Jack's, but they are standard.
/ PJ trailer #17
I also read that about using 50/50 boiled linseed oil and turpentine as a wood preserver when you want to paint over it. I made wooden frames for window screens on an old house I had one time and put it on the window frames before painting them. They have been in use about 30 years and still holding up well. After I sold that house the new owner called me and asked if I would make screen frames for another old house he had. I was honored to be asked but declined.
I'm glad it came up because I'm now going to consider treating the new floor I put in my 16' trailer with boiled linseed oil/turpentine.
/ PJ trailer
I used mineral spirits because I had it. Figured it would thin it out and evaporate away. Dont know if it helped or hurt.
/ PJ trailer #19
I used 1/4 diesel with 3/4 boiled linseed oil the first time I treated the wood floors on my 20' PJ. After 9 years sitting out in the weather unprotected in any manner, I went ahead and hit it again last month with a coat of straight linseed oil.
The linseed oil worked so well I also coated my new Karavan utility trailer floor last month. It too, sits outside. I can only hope that the floor in it lasts as well as the PJ. I was however, shocked at the current price of linseed oil, now about $27/gallon! What a rip. Fortunately, a half gallon covered both trailers.
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
CAT J600 Teeth (2) (A68134)
CAT J600 Teeth (2)...
2019 Ford F-150 Ext. Cab Pickup Truck (A66736)
2019 Ford F-150...
GROVE RT520 ROUGH TERRAIN CRANE (A67714)
GROVE RT520 ROUGH...
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
