PJ 16' Tilt
/ PJ 16' Tilt #11
I have an '01 F250, Diesel, the hitch is rated at 5K and 12.5K w/wd hitch. I checked my hollow mount and it is only rated at 5K.
My wd hitch for my enclosed car trailer is rated at 12K. The problem I have is where they mounted the electrical boxes on the tilt trailer, of course they are in the way of where the brackets have to mount.
Thanks, Mike
I would seriously consider upgrading the hitch. I have seen 2 break on Superdutys. One was mine and another was also overloaded and broke on the boat ramp.
I would look at something like the Class 5 2.5" Reese Titan. They are good for about 14,000# without WD. I have one on my 04 F-250 that I broke the hitch on.
Chris
/ PJ 16' Tilt #12
The SD's also came with an optional 2.5" class 5, I think 12,000 lb non wd, 16,000 lb with wd. I got mine from a guy installing a wheel lift. It came off a 2009 dually truck, fit perfect on my 2001 SD srw.
/ PJ 16' Tilt #13
Diamondpilot > just curious how your hitch broke. Did it snap completely off? How much tongue weight do you think you had on it? I would hate for that to ever happen to me....
/ PJ 16' Tilt #14
I was pulling a boat that weighed 14,600# back from the Pittsburgh area to Indiana. I was told the boat weighed 12,000# which was still above the hitch rating but when I had it weighed that's when I found out it was 14,600#.
Anyway, I made it home and went to unhitch it and though it looked funny but it was dark. The next morning I went out to hitch up another trailer that used a 2" ball instead of the 2 5/16" ball I had in. When I went to pull the pin I noticed the pin box was bent down, the welds were cracked 3/4 of the way through, and the pin hole was wallered out 3/8" extra.
The tongue weight was about 1,600# at that time. When I fueled the boat and added water and supplies it was about 1,800#
This was all on a basically new truck less than one year old.
Chris
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
DEUTZ MARATHON...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2026 Kearney 102" x 32' Gooseneck (A60462)
2026 Kearney 102"...
