PJ 16' Tilt
/ PJ 16' Tilt #1
scodemike
Monument, CO.
LS XR3135HC
Just wanted to get opinions on whether to buy this or not; PJ tilt bed equipment trailer
My only concern is that is only a 16', although it measures 17' from front of the deck to the tip of the ramps at the rear. I measured my 3320 with the bucket flat and the rear blade at an angle it measure 15' 10". If I roll the bucket back and straighted the blade I gain a foot and half or so. I really like the trailer, tilt and heavy duty, it looks new and I think I can get it for $3K
Opinions?
/ PJ 16' Tilt #2
I say yes, its worth it. Any 14K trailer for that money is a good buy. Offer $3000 in $100 bills and you will drive away with it. If not leave. He will call you within a hour to come get it.
Chris
/ PJ 16' Tilt
My thought exactly. I was very impressed with the appearance of it and they sell for $5200 new, w/o LED upgrade.
/ PJ 16' Tilt #5
Opinions?
Recently I checked out that model at the local PJ dealer. Nice rig, looks solid. Price you're looking at seems reasonable for a trailer that has everything you need already installed.
/ PJ 16' Tilt
I agree it is well built trailer and just what I wanted. However, I was suppose to sell a car this past Saturday and use some funds from that to buy the trailer. Well the guy decided the car was not what he wanted, so I had to pass on the trailer for now.:mur:
/ PJ 16' Tilt
/ PJ 16' Tilt #8
I'm thinking that it's a bit overpriced. I just bought a galvanized solid w/ball. $35 for the mount & $20 for the ball. That's new and at a trailer supplier. ...just a thought.
/ PJ 16' Tilt #9
Yes, you should get a mount and a ball that are rated to what your trailer is. Also take a look at your hitch itself. Not many are rated at 14,000# unless you get into a class 5 hitch that is 2.5" or some 2" units from a few companies.
I have a 2004 F-250 4x4 Diesel and when it was about 6 months old I broke the factory hitch with a 14,600# load. The hitch was rated at only 6,000# and 10,000# with WD if I remember right. It could have been 7,500# and 12,000# but either way I had it overloaded and it broke. Remember, it was a brand new truck.
What is your tow vehicle?
Chris
/ PJ 16' Tilt
I have an '01 F250, Diesel, the hitch is rated at 5K and 12.5K w/wd hitch. I checked my hollow mount and it is only rated at 5K.
My wd hitch for my enclosed car trailer is rated at 12K. The problem I have is where they mounted the electrical boxes on the tilt trailer, of course they are in the way of where the brackets have to mount.
Thanks, Mike
/ PJ 16' Tilt #11
Thanks, Mike
I would seriously consider upgrading the hitch. I have seen 2 break on Superdutys. One was mine and another was also overloaded and broke on the boat ramp.
I would look at something like the Class 5 2.5" Reese Titan. They are good for about 14,000# without WD. I have one on my 04 F-250 that I broke the hitch on.
Chris
/ PJ 16' Tilt #12
The SD's also came with an optional 2.5" class 5, I think 12,000 lb non wd, 16,000 lb with wd. I got mine from a guy installing a wheel lift. It came off a 2009 dually truck, fit perfect on my 2001 SD srw.
/ PJ 16' Tilt #13
Diamondpilot > just curious how your hitch broke. Did it snap completely off? How much tongue weight do you think you had on it? I would hate for that to ever happen to me....
/ PJ 16' Tilt #14
I was pulling a boat that weighed 14,600# back from the Pittsburgh area to Indiana. I was told the boat weighed 12,000# which was still above the hitch rating but when I had it weighed that's when I found out it was 14,600#.
Anyway, I made it home and went to unhitch it and though it looked funny but it was dark. The next morning I went out to hitch up another trailer that used a 2" ball instead of the 2 5/16" ball I had in. When I went to pull the pin I noticed the pin box was bent down, the welds were cracked 3/4 of the way through, and the pin hole was wallered out 3/8" extra.
The tongue weight was about 1,600# at that time. When I fueled the boat and added water and supplies it was about 1,800#
This was all on a basically new truck less than one year old.
Chris
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
Amadas SPC-6 (A64119)
2005 Ford F-150 Ext. Cab Pickup Truck (A61573)
2005 Ford F-150...
