Piranha tooth bar!!!
/ Piranha tooth bar!!! #141
Nice to hear stories of good customer service...
I was a toothbar skeptic and decided to buy a Markham solely on TBN research and I've never taken it off... does a great job with the soil conditions I have.
/ Piranha tooth bar!!! #142
Used my PTB for about two hours today. I'm very impressed with it and it really helps in the woods. I was able to take out a few small stumps that have been dead for a while just with the toothbar. This probably wouldn't have been possible with the bucket alone.
Just wanted to add my two cents to anyone considering one. If I ever have a cameraman around I will shoot some video.
/ Piranha tooth bar!!! #143
I finally got my PTB put on.
Just out of the package. Notice the missing cutouts for quick-on forks. I requested no cutouts since I don't plan to add forks to the bucket.
Testing the initial fit on the bucket. I tapped the bar with a 4 lb hammer (2x4 between them to keep metal from hitting) to set it as tight as it should be when it's installed. Then I added the welding clamps to keep the bar against the cutting edge. I tapped the bar some more just to make sure everything was tight.
Marked the holes with a permanent marker. Drilled pilot holes with 1/4" bit. The instructions said a smaller size, but 1/4" fit the first step of the step bit better. The final size of the hole was one step below 3/4". When you get close to the final hole size check the bolt in the hole to make sure you don't go too big.
A note about step bits: Don't go too fast and be careful. They like to grab the hole and will twist the drill in your hands. When you get the hole to the correct size run the bit on the other side to clean up the hole.
20150115_191654 (Small).jpg 20150115_191703 (Small).jpg 20150115_191710 (Small).jpg
Toothbar fully installed. Make sure you tap the bar with the hammer and keep everything tight. Tighten your bolts and you're done.
20150115_192503 (Small).jpg 20150115_192509 (Small).jpg 20150115_192520 (Small).jpg 20150115_192526 (Small).jpg 20150115_192559 (Small).jpg
Looking good. Just watch yourself walking around the bucket now. It took a couple of bites out of my ankles until I gave it proper distance. It's a little beast. Also took a chunk out my fence and a deck post getting used to the extra length.
/ Piranha tooth bar!!! #145
I was watching the Legend of Mick Dodge on Nat Geo last night. Micks buddy had what looked like a PTB on a L235.
/ Piranha tooth bar!!! #146
jjs, nice write-up with pics!
I remember someone else saying that when they installed, they decided to reverse the bolt/nut direction. Their thought was that the bolt end may get buggered up some and may make the nut hard to remove. Don't know if it's really anything to worry about, but seeing your pics reminded me of that, and thought I'd just mention it...
/ Piranha tooth bar!!! #147
Installed my PTB on the new BX25D today. Must have taken all of 5 minutes to drill and install. Now just need to destroy something..:thumbsup:
/ Piranha tooth bar!!! #148
The youngest and I cleared off more of the property today. The PTB really helped.
/ Piranha tooth bar!!! #149
You guys are gonna love it, I personally think it's the best bang for the buck add on to a SCUT or any other loader of reasonable size.
/ Piranha tooth bar!!! #150
Thanks to jjsjeff for his detailed instructions. I followed to T and installed my PTB on my L4600. Can't wait to start using it. image.jpg
Mike
/ Piranha tooth bar!!! #151
Received my step drill bit set last week so had a chance to drill final holes on bucket last Friday.
Step drill really works well and saved a lot of time. Took less than 2 minutes per hole starting with a 3/16" pilot hole.
The PTB bolted right up with no issues.
I'm anxious to get out to use it.
/ Piranha tooth bar!!! #152
Received my step drill bit set last week so had a chance to drill final holes on bucket last Friday. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407578-piranha-tooth-bar-20150117_100051-jpg"/> Step drill really works well and saved a lot of time. Took less than 2 minutes per hole starting with a 3/16" pilot hole. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407586-piranha-tooth-bar-20150117_104440-jpg"/> <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407587-piranha-tooth-bar-20150117_104611-jpg"/> <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407579-piranha-tooth-bar-20150117_104624-jpg"/> The PTB bolted right up with no issues. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407588-piranha-tooth-bar-20150119_142522-jpg"/> I'm anxious to get out to use it.
Looks great! Nice install! Let us know how it works.
/ Piranha tooth bar!!! #153
/ Piranha tooth bar!!! #157
/ Piranha tooth bar!!! #158
Hi Maxi,
Welcome to TBN, I have learned a ton here.
I have had a PTB since 2013, and was referring to a bucket grapple in my comment above.
Did you realize that you replied to a post from 2015?
Thanks though... it was a good video.
P.A.
I was not sure but I also have the PTB and it works great on my GC1720.
OP here... yep have been using mine on my BX for 7 years now. Lots of digging for tractor paths and terracing, and a bunch of gravel and dirt moving. Working as good as day one.
/ Piranha tooth bar!!! #160
My Markham tooth bar has never been off the BX... really transformed machine capabilities.
I don't think Markham is around anymore and I bought it 15 years ago... time flies.
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
