Piranha tooth bar!!!
   / Piranha tooth bar!!! #151
Received my step drill bit set last week so had a chance to drill final holes on bucket last Friday.
Step drill really works well and saved a lot of time. Took less than 2 minutes per hole starting with a 3/16" pilot hole.
The PTB bolted right up with no issues.
I'm anxious to get out to use it.
   / Piranha tooth bar!!! #152
Received my step drill bit set last week so had a chance to drill final holes on bucket last Friday. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407578-piranha-tooth-bar-20150117_100051-jpg"/> Step drill really works well and saved a lot of time. Took less than 2 minutes per hole starting with a 3/16" pilot hole. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407586-piranha-tooth-bar-20150117_104440-jpg"/> <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407587-piranha-tooth-bar-20150117_104611-jpg"/> <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407579-piranha-tooth-bar-20150117_104624-jpg"/> The PTB bolted right up with no issues. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/407588-piranha-tooth-bar-20150119_142522-jpg"/> I'm anxious to get out to use it.
Looks great! Nice install! Let us know how it works.
   / Piranha tooth bar!!! #153
   / Piranha tooth bar!!! #157
take a look on youtube there are several example.
Piranha Tooth Bar Review - YouTube
Hi Maxi,
Welcome to TBN, I have learned a ton here.
I have had a PTB since 2013, and was referring to a bucket grapple in my comment above.
Did you realize that you replied to a post from 2015?
Thanks though... it was a good video.
P.A.
   / Piranha tooth bar!!! #158
Hi Maxi,
P.A.
I was not sure but I also have the PTB and it works great on my GC1720.
OP here... yep have been using mine on my BX for 7 years now. Lots of digging for tractor paths and terracing, and a bunch of gravel and dirt moving. Working as good as day one.
   / Piranha tooth bar!!! #160
My Markham tooth bar has never been off the BX... really transformed machine capabilities.
I don't think Markham is around anymore and I bought it 15 years ago... time flies.
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
Deere 331G (A53317)
Deere 331G (A53317)
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
2017 Ford T350 van (A55973)
2017 Ford T350 van...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
