Pipe Threads #$%^&
   / Pipe Threads #$%^& #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
I've added some hydraulic lines to my tractor and had to use pipe threads in a few places. I used thread sealant on all pipe threads, but have a single fitting that leaks. I've gotten all but one tight enough to not leak, but the one is driving me up a wall. It is a 1/2" pipe thread quick disconnect at the end of a 6' hydraulic hose and it's leaking around the threads. It is possible to remove the hose but would be a lot of work to do so. I have crescent wrenches up to 2' (in length) for leverage but trying to tighten it further has been unsuccessful. My next step is to see if I can get a deep impact socket to fit over the QD but that will be several weeks before I can get into a town that has one. Any suggestions?
   / Pipe Threads #$%^& #2
If it’s a drip and you don’t ever need to get it off, jbweld?
   / Pipe Threads #$%^& #3
I've done just a little work on hydraulics. I used pipe dope that listed on the can it is suitable for hydraulic lines. No leaks.
   / Pipe Threads #$%^& #4
   / Pipe Threads #$%^& #5
Pipe dope and teflon tape has worked for me on NPT stuff
   / Pipe Threads #$%^& #6
+1 on the teflon tape/thread dope. Could it be that the male fitting is bottomed in the female? Trying to tighten further would just strip threads and make things worse.
   / Pipe Threads #$%^& #7
Permatex No 2, thicker than No 3. :)
LocTite 567 is a 'high-temp' alternate to 565. These two aren't like the 'green stuff' and most other teflon-based brush-on dopes. They have a working time (~5 min) and a curing time (20-30 min) like many of the company's products. This gives them an edge over more basic plumbing dopes.
IMO, Parker fittings are worth the $$ for better fits, fewer rounded hexes when tightening to stop leaks, and fewer 'do-overs'.
TSC stuff (hoses w/NPT male ends) is among the worst we can easily find. I suggest 'chasing' the lumpy plating off their male NPT threads with a regular die set. :2cents:
   / Pipe Threads #$%^& #8
Over tightening sae pipe threads causes more problems then it solves.
A small amount of a teflon pipe dope or 3 wraps of teflon tape should be sufficent to seal a npt fitting.
If it needs more the fitting is low quality, teflon tape is not a sealant anyways it is a thread lubricant allowing the thread distortion to occur which is what seals npt threads.
   / Pipe Threads #$%^& #9
.. A small amount of a teflon pipe dope or 3 wraps of teflon tape should be sufficient to seal a NPT fitting.
If it needs more the fitting is low quality, teflon tape is not a sealant anyways it is a thread lubricant allowing the thread distortion to occur which is what seals NPT threads.
This! ^^^ :thumbsup:
   / Pipe Threads #$%^& #10
Had a sae NPT fitting leak on loader last year, no amount of thread dope/tape would seal it, had to replace fitting.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED JCT 72" HYD 4N1 BUCKET (A54757)
UNUSED JCT 72" HYD...
Mobile toilet with shower (A53424)
Mobile toilet with...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
2019 BOBCAT E50 EXCAVATOR (A52705)
2019 BOBCAT E50...
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
