Pipe Threads #$%^&
   / Pipe Threads #$%^& #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
I've added some hydraulic lines to my tractor and had to use pipe threads in a few places. I used thread sealant on all pipe threads, but have a single fitting that leaks. I've gotten all but one tight enough to not leak, but the one is driving me up a wall. It is a 1/2" pipe thread quick disconnect at the end of a 6' hydraulic hose and it's leaking around the threads. It is possible to remove the hose but would be a lot of work to do so. I have crescent wrenches up to 2' (in length) for leverage but trying to tighten it further has been unsuccessful. My next step is to see if I can get a deep impact socket to fit over the QD but that will be several weeks before I can get into a town that has one. Any suggestions?
   / Pipe Threads #$%^& #2
If it’s a drip and you don’t ever need to get it off, jbweld?
   / Pipe Threads #$%^& #3
I've done just a little work on hydraulics. I used pipe dope that listed on the can it is suitable for hydraulic lines. No leaks.
   / Pipe Threads #$%^& #4
   / Pipe Threads #$%^& #5
Pipe dope and teflon tape has worked for me on NPT stuff
   / Pipe Threads #$%^& #6
+1 on the teflon tape/thread dope. Could it be that the male fitting is bottomed in the female? Trying to tighten further would just strip threads and make things worse.
   / Pipe Threads #$%^& #7
Permatex No 2, thicker than No 3. :)
LocTite 567 is a 'high-temp' alternate to 565. These two aren't like the 'green stuff' and most other teflon-based brush-on dopes. They have a working time (~5 min) and a curing time (20-30 min) like many of the company's products. This gives them an edge over more basic plumbing dopes.
IMO, Parker fittings are worth the $$ for better fits, fewer rounded hexes when tightening to stop leaks, and fewer 'do-overs'.
TSC stuff (hoses w/NPT male ends) is among the worst we can easily find. I suggest 'chasing' the lumpy plating off their male NPT threads with a regular die set. :2cents:
   / Pipe Threads #$%^& #8
Over tightening sae pipe threads causes more problems then it solves.
A small amount of a teflon pipe dope or 3 wraps of teflon tape should be sufficent to seal a npt fitting.
If it needs more the fitting is low quality, teflon tape is not a sealant anyways it is a thread lubricant allowing the thread distortion to occur which is what seals npt threads.
   / Pipe Threads #$%^& #9
.. A small amount of a teflon pipe dope or 3 wraps of teflon tape should be sufficient to seal a NPT fitting.
If it needs more the fitting is low quality, teflon tape is not a sealant anyways it is a thread lubricant allowing the thread distortion to occur which is what seals NPT threads.
This! ^^^ :thumbsup:
   / Pipe Threads #$%^& #10
Had a sae NPT fitting leak on loader last year, no amount of thread dope/tape would seal it, had to replace fitting.
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
(4) 8 LUG WHEELS (A54756)
(4) 8 LUG WHEELS...
ROADHOG CP24 SKID STEER HYD COLD PLANER (A54756)
ROADHOG CP24 SKID...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
