Pipe Threader
/ Pipe Threader #51
The issue with the China threading dies is one, improper heat treat and two, the inserts aren't machined square. Peruse various estate sales and auctions and buy a Rigid or Williams, you won't be sorry. Did my entire shop in 1.5" black iron and of course used quality pipe dope.
I have the HF ratcheting die stocks as well and all the inserts needed to be removed and ground square to actually cut threads. Did that on my surface grinder. Finally, not just any oil will suffice. You need to use a sulfur based cutting oil which is an EP additive. I tend to use Tap Magic buy 'stinky' oil at any plumbing outlet.
Motor oil will only cause bad threads and galling.
I would have preferred NPT Dryseal thread dies but they are rare.
/ Pipe Threader #52
Thanks.
I tried using two large (24") pipe wrenches, but that didn't work, so I put the pipe in my 6" Wilton bench vice and cranked down hard ... I know that's not ideal, but it worked.
haha! Yeah, been there, done that. I have two pipe vises now, one bench mounted and the other a tripod. But I didn't always have them, which is why I had asked. Not easy!
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
Manure spreader for sale
Manure spreader...
