Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #6,681
Unchained R4s aren't that good for winter traction, I believe unchained turf tires do much better.
Here's a previous discussion about R4's vs turfs in snow.
/ Pictures of your snow weapons #6,683
They turn into racing slicks
/ Pictures of your snow weapons #6,684
Well, I removed what my friends refer to as my "***** slippers" and set them aside; cleaned up the bucket, and put the wear bar back on.
I expect at least a foot of snow over the weekend.
/ Pictures of your snow weapons #6,685
Yep, I surprised that we haven't been hit with a late season blizzard,
I dropped the chains of the Branson, they stay on the IH,
swapped out our studded snow tires for the summer tires on both vehicles last week and it hasn't snowed yet.
/ Pictures of your snow weapons #6,688
Won't be long now before collectors start looking for machines of this vintage, and that one is quite nice.
Thanks just bought it last fall for $3500 with 700hrs. Would never pay $20 or $30,000 for a tractor with a computer. I want it to run the way I want not the way the government thinks it should.
/ Pictures of your snow weapons #6,690
You know I have turf tires on my Kubota l-245dt and got chains with it and never had to put them on. I can go through over a foot of snow plowing and it doesn't slip at all.
Same here. I never chain up to plow, or really for any winter chore other than pulling a wagon or trailer through deep snow. The wagon axles tend to create enough drag in deep snow that I can get stuck with that, even in 4wd, if I don't chain up.
In our climate, we usually get enough melt and/or re-freeze that I can time my schedule of refilling the wood wagon between storms, when the snow is either hardpack or gone. This helps me avoid having to handle 41" tire chains, which seem to get heavier each year.
/ Pictures of your snow weapons #6,691
Always surprised by the ones that can handle snow plowing without chains. Then I remember that not everyone has steep hills to handle.
/ Pictures of your snow weapons #6,692
My first CUT was a JD 955. I reworked a set of semi truck chains to fit and ended up never using/needing them.
With my present 4410 I've only ever wished for chains once since 2004. It was a really wet snow and it turned to ice as soon as the tires put pressure on the snow. No traction at all!
/ Pictures of your snow weapons #6,693
Where i live, snow always turn to ice. Always have freeze, than thaw, then freeze then snow. Without chains my tractor plows sideways on flat ground.
/ Pictures of your snow weapons #6,694
Same here - snow turns to ice. Don't even need a thaw freeze cycle. Just continually driving over snow that doesn't melt off hard packs it into ice.
gg
/ Pictures of your snow weapons #6,695
Same as well...plowing with tractor rear tire chains only have to be ready to counter steer going around curve.
/ Pictures of your snow weapons #6,696
Very hilly here. My kitchen windows actually look out onto a ski slope. I guess my driveway is relatively flat, by comparison to some, but even my neighbors with more hilly drives seem to be doing them without chains. All are asphalt, though, which is probably key. If I were on gravel, I'd probably be running chains.
/ Pictures of your snow weapons #6,699
No pictures, because I don't know how.
TYM 674 with cab. 72" inverted snow blower and a 72" snow pusher.
We'll see how the R1's do this winter.
/ Pictures of your snow weapons #6,700
Rainy Lake, Ontario side not Minnesota side
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
2003 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2003 CATERPILLAR...
JOHN DEERE 7230R TRACTOR (A60430)
JOHN DEERE 7230R...
UNUSED I/A 12F 12' HYD BOX SCRAPER (A60430)
UNUSED I/A 12F 12'...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
