Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,361
Indeed that taste of warm spring was noting but BIG tease. ;(
yep, and mud under the danged snow:thumbsdown:
   / Pictures of your snow weapons #4,362
Well, with the wind it is hard to say what the final total was. Over a foot for sure. The ground is so soft it is impossible not to rip up grass in spots. My neighbors sure are glad to see the orange beast cleaning up there driveways for them. Didn't get any pictures this time.
   / Pictures of your snow weapons #4,364
The Pronovost 64 and the Cabota handled it just fine, considering that it's 33° out there and this stuff is HEAVY.
Biggest challenge was getting the angle of the dangle on the blower set so it'd cut without either packing it down and riding over the top, or digging in and blowing half the driveway into the grass.
   / Pictures of your snow weapons #4,365
Here in China, Maine we've got about 20" but it's still snowing! I'm using the BX25 to clear enough so I can then get the plow truck moving without getting stuck. Wet heavy stuff! I use the FEL and home made back blade to put it where I want it.
This is what it looked like outside the shed doors.
   / Pictures of your snow weapons #4,367
22" as best as I can tell, it blew pretty good. It was pretty heavy and even "tighter" with today's above freezing temps.
Then the rest of the snow came off the lean too roof.
   / Pictures of your snow weapons #4,368
Great!
   / Pictures of your snow weapons #4,369
With all the April snow storms hitting this Spring '18, thought we'd see more snow 'weapons' pics. But maybe the 'weapons' were removed too soon... as was my snow plow. I hate having to move snow with the bucket on the FEL, but the plow was put away three weeks ago when the weather was right for doing Spring work. Ha! One more snow, they're saying, for tomorrow.
   / Pictures of your snow weapons #4,370
I just came in from blowing my driveway. We had mild temps, freezing rain and on top of that 2 inches of wet snow. I didn't think it would of been easy cause it is 32 wet especially under the snow. So I took my time and skimmed the top of the driveway in low gear and did not use the float trying not to hit the gravel etc. Worked out fine I would never been able to push that snow with the ATV so glad the blower was still on my machine. Where the heck is Spring lol.
   / Pictures of your snow weapons #4,371
"Where the heck is Spring"
Cheer up in couple months or so we start losing day light mins....duck'n running. ;)
   / Pictures of your snow weapons #4,372
'tis true. Well, 2 months and a few days, if you want to get all scientific...
On a couple-post-back note, this recent event has got me thinking maybe I should have a back blade in inventory. Front-mounted snowblower is my Ultimate Answer, but I don't think ANY snowblower would handle the 1" of sleet doused with a double-shot of rain we got in this last storm. At our (vacated within one day) previous house it would be no big deal - almost flat driveway. But our new house has a pretty challenging positive slope incoming. Took me three tries (well, I didn't really expect much on the first try as I just did the normal 90° approach from the road). This stuff was like driving on a dump of ball bearings.
   / Pictures of your snow weapons #4,373
I have the front mount 66" snowblower and rear blade on my CK and love it.
I blow just about anything with it unless it is really wet then I push with the back blade. When there is not enough snow to blow then I pull out my ATV 700 kawasaki with snow blade on front. Either way I have the machines to do it with. Love winter lol
   / Pictures of your snow weapons #4,375
From Friday through Tuesday, Gaylord hs had over 20+ inches of that white sh.....t! I would have to check how many hours I was in my tractor. One customer said he had 22", dad figured 30", and I opened a 3/8 mile drive that had approximately 30" in it. That alone took 10 hours. Gas station guys were laughing at me because I was in there 3 times over that period. Which is about 8 hours per tank of deisel.
I measured the blower top height was at 22" from the ground.
   / Pictures of your snow weapons #4,377
I've been trying to find a blower for my old F2100, but haven't had much luck. In the meantime, I welded up a mount for an ATV plow to fit. I really need to add box sides, power angle and a mold board extension, but I've vowed to have a proper tractor come next winter. Make no mistake though, this old girl can push like beast, even with the turf tires.
These are from a few years ago. Approx. 24inin a short span came down.
   / Pictures of your snow weapons #4,378
If you have a PTO shaft out front for the deck, you should be able to use most any front mount blower that spins in the correct direction.
Aaron Z
   / Pictures of your snow weapons #4,379
Hysyde,
This fellow took a conventional used 540 rpm snow blower, ton of used models in circulation, and added a gas driver motor. If you are handy, fabricating a mount should not be difficult. I enclose a screenshot, the info in top dialog box should help you find the thread. Poster was very helpful in sharing his experience. He had more photos, specs, engine was 22 hp honda, shared his cost factors as well.
   / Pictures of your snow weapons #4,380
Bunch of years ago I front mounted a 48" blower which I drove with a 16HP Wisconsin that had electric start.
I duplicated FEL mounts and had it installed on my FEL arms.
It was awesome as I could raise the blower and blow away high snow and even a deck etc.
It was really not a difficult installation at all.
Problem was that came spring I got ambitious and the blower discovered a hidden car starter and totally trashed the augers and blew open the gear box.
What I did not know was that the augers were completely 'rust welded' to the shaft so there was no protection or weak link. (this was IMHO a bad design flaw as there was no provision to lubricate the auger shaft and also the shaft was simply a 1" shaft in a 1" tube so rust weld probably occurred real fast.
(Later similar blowers use a larger tube with zerks and bushings.)
My current 60" is same make as the trashed 48", LOL so I have a few spare parts.
2432 (A60432)
2432 (A60432)
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
2353 (A60432)
2353 (A60432)
