PICTURE HELP
/ PICTURE HELP #1
ALHILLDIRT
ALABAMA
Kubota GL3240
I have a YM 2010, bought used. I believe it is missing some parts on the draft control lever/linkage, and my shop manual doesn't really give any pictures that can help me to determine what is missing. Anyone out there have a 2010 that they could either post or email me some pictures of what this looks like with everything there?
/ PICTURE HELP #2
How's this?
This is YM240/YM2000, so it should be similar.
/ PICTURE HELP
Thanks for the pictures. I think mine is different, but I need to study your pictures in relation to my tractor.
/ PICTURE HELP #4
I would like to see a picture of the part that goes on the tiller.
/ PICTURE HELP #5
Think there has been several designs over the yrs but think a flex cable is fairly common.
I'm presently working on getting mine connected up correctly. No problem at the tractor but I'm missing a part or two at the tiller. Going over to Ernie's and he is going to show me how to connect and give me the missing part(s). Will post a pic or two when I've got it all hooked up and working correctly.
/ PICTURE HELP #6
Thanks Mickey,
Looking forward to seeing them.
/ PICTURE HELP #7
Eddie said:
Thanks Mickey,
Well, here are a couple prelim pics.
Due to using a qiuck mount hitch I had to fab a bracket to hold the cable at the tractor end. Everything is held in place with small hairpin clips.
As I mentioned in previous post, there has been numerous designs for the tiller end. Looking around at Ernie's today I saw several variations in the cable control mechanism I had not seen before. Ernie gave me one I liked a lot better than the bracket that was missing on mine and also mounted on the left side which helps some with cable length since the tiller is mounted further back with the quick mount hitch.
On the tiller end, the mechanism mounts to the flap close to the hinge point. I'll need to fab a bracket to support the link rod and hold the end of the cable. As the flap lifts, the link rod moves fwd, pulling on the cable. The cable pulls on the sense link at the tractor. This sense link is tied in to the "draft control" lever. The draft control lever sets the point when the movement of the tiller flap tells the 3pt arm to raise or fall, thus controlling the tiller depth. The mechanism on the flap has 2 positions. When at the aft position it unloads the cable to the point the flap will not pull on the sense link at the tractor. In the fwd position the cable has had some tension placed on it and now it pulls the sense link.
Hope this description describes what is going on.
While at ernie's I acquired a sensor that mounts to the tiller and functions with the UFO control electrically to automatically level the tiller on the fly. The way I understand this item it is a switch mechanism that sends signals to the UFO control which determins when the UFO needs to either raise or lower the hyd cyl on the right 3pt lift thus leveling the tiller.
Will try and remember when I get it all mounted, get all the links set to the correct place and learn how to operated the auto level, I'll make another post telling how it works and a couple pics to show the finished set-up.
I Partisipate in several tractor forums and yet to read of anyone having the depth and leveling mechanism hooked up and working on their tractor. Maybe a first and maybe helpful to others.
/ PICTURE HELP #8
Hi, as we can see Mickey is our UFO expert; this link may help a little about horizontal control;i think we need another type of control...
ƒiƒCƒXƒeƒB UFO
/ PICTURE HELP #9
When it comes to the UFO controls, one doesn't need to know much to be considered an expert.:p
Being an old M.E. I do have some ability to figure out some things on my own and that's where any and all knowledge I might have has come from.
Trying to get the auto tilt control to work is going to take some doing as when I plug in the sensor the tilt hyd cyl wants to retrack and when it is fully retracted it doesn't want to release the hyd pressure. Gonna take some work to figure out if the problem lays with the sensor or something in the UFO control box or wiring.
If there is any interest expressed, I'll try and post what I find with regard to what control does what. Think I should start a new thread just about UFO controls and I might throw in what I learned about the auto depth control for the tiller as well.
(10) New CATERPILLAR Keys (A65579)
(10) New...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
(2) Caterpillar Skidsteer Tires (A66408)
(2) Caterpillar...
2016 KENWORTH T800 TRI-AXLE (A65643)
2016 KENWORTH T800...
6' Picnic Table (A66408)
6' Picnic Table...
New 215/50-10 NHS tire on 5-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 215/50-10 NHS...
