PHD Trouble
/ PHD Trouble #1
40_acre_mule
South Mississippi
Kubota L4701
I bought a Howse PHD with a 12in auger.
It worked fine for the two times I used it:
once right after purchase, maybe 20 holes.
next time 6 months later, maybe 15 holes.
Then about 8 months later, there's a big puddle of oil under it, leaking from the drive shaft and from the auger shaft. Talk to the dealer and find out that not only does Howse NOT sell parts for the gear box, Howse doesn't even have a parts breakdown for the gearbox. So, I can't even find out what parts I need, much less order them.
I haven't tried to take the thing apart yet, but that's the next step. I am guessing I will need seals, or bushings, or bearings, or a combination thereof.
The name on the gearbox is Cheetah.
Do any of y'all have good source for bearings or seals, so I can match what's in there?
Any weird stuff to watch out for during disassembly?
Thanks,
Mule
/ PHD Trouble #4
You may consider just putting pourable or other grease in it unless its a really bad leak. Almost as good as oil & cheaper/easier than replacing seals.
/ PHD Trouble #5
If I wanted to replace the seals, bushings, or bearings, I think I'd take the bad ones to one of my local bearing supply houses and see if they could help me.
/ PHD Trouble #6
I'll echo what stuckmotor said. Remove the seal so you can measure shaft diameter, bore size and thickness of the seal. I'm fortunate to have Motion Industries, Applied, and Bearing Service Co. all here in Kalamazoo.
/ PHD Trouble #7
I'd drain the 90wt oil out of the gear case and fill it with John Deere's corn head grease. It is thick when cool and thin when hot. It was made for sloppy bushings and seals.
/ PHD Trouble #8
I recently lost a 200 hp gear box due to lack of oil. There was no sign of oil leak.
I talked to several dealers and more than one said instead of 90wt gear oil I should use grease like from a grease gun. They said farmers around hear have been using that for years with no issues.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
